| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: GR86
Brake rotor wear after 3 track days
After 3 track day with Hawk DTC 60, the front rotors look like this. The rotor surface is smooth
Should I replace them immediately? |
#2 |
30 minute maintenance
Drives: My18 wrxsti
#3 |
ProCrastinationConsultant
Lol, 'completely broken car', location:Germany
https://www.google.com/amp/s/nomoney...ur-rotors/amp/
#4 | |
Drives: '15 GT86 & '22 GR86
Your hysteria is not welcome, especially as you do not completely understand what it is you are advising against. |
#5 |
Drives: -
Ok. Then sorry fot that.
I deleted my posts to avoid further confusion. Btw. I googled before i posted, i found several warnings, but i'm definivly not as deep into this, than others. E.g. i found this is considered as "will break under load". https://www.at-rs.de/files/blog/Scha.../Bild-3-T2.jpg So whats the difference? |
#6 |
Drives: -
#7 |
Drives: GR86
Thanks for all feedbacks.
Does that mean the pad is too aggressive for the rotor? Or/and the rotor exceeded operating temperature? If I upgrade to a better performance rotor, will the rotor have heat checking again from track use? |
#8 |
Drives: My18 wrxsti
1 possibly 2 did the rotors change color or warp? 3 Maybe (checking? I presume you mean the surface cracking/crazing)
what brake fluid, did they fade? Might change my answer to 1 maybe 2 but not 3 |
#9 | |
Drives: GR86
I didn’t experience any brake fade / soft pedal feel at the track. |
#10 |
Drives: '22 GR86
Are you using any of the nannies, traction/ stability control? They use the brakes to control wheel speed and create a lot of excessive heat on the brake system.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
#11 |
You should try cryo treated rotors for your next set. I heard after they sit in -300F freezers they can last up to 3x longer.
#12 | |
Drives: GR86
It could be from rt660 tires. I go full speed at the track; I really “drive” the car. |
#13 |
Drives: '22 GR86
Track mode still has some but minimal intervention. Long pressing the trac off button turns everything off
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD Last edited by staples323; 04-11-2022 at 04:48 PM. Reason: spelling |
#14 |
Drives: GR86
| Brake pads to swap between for DD and Track Days | jim985 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 12-25-2020 08:12 PM |
| Brake compound for Track Days | fer3d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-31-2018 08:47 AM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
| NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days | 86_Insider | Brakes, Suspension, Chassis | 1 | 09-26-2013 01:39 AM |
| Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
