| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2015 Scion FR-S Firestorm
TPMS battery replacement?
Hey guys,
I'm about to switch my original primacy hp to something else as the tires are worn and aged (second owner, they should be original tires). Something like Bridgestone Potenza Sports is being considered now. While changing my tires, I was wondering if I can replace the battery for the tpms sensors. I've looked up the forum but cannot find anything mentioning the battery. It's 2015 model, so I thought I might as well replace the battery too. I was hoping to bring the battery to the tire shop myself and try to avoid extra fee for replacing tpms battery by themselves (if it's a thing). Thanks! |
#2 |
Drives: Scion FRS
Most tire shops will charge you for a TPMS kit, which includes new O-ring, and battery. I had mine done recently so I can see if they put a PN on my invoice.
| The Following User Says Thank You to markitect For This Useful Post: | suppjc (04-06-2022) |
#3 |
Wheels for Brains
No. The OEM TMPS are completely sealed.
If it runs out of battery, you need to buy a whole new TPMS unit. Maybe some aftermarket TPMS have replaceable batteries, but it's unlikely |
| The Following 2 Users Say Thank You to EndlessAzure For This Useful Post: | saltywetman (04-06-2022), suppjc (04-06-2022) |
#4 |
Drives: 2020 Toyota 86 GT 6M
I never knew tpms batteries are replaceable either. I thought they were sealed and sensors have to be replace once the juice runs out.
Looking at youtube how to videos on replacing the batteries they all seem to be home hack jobs rather than something a shop would do. Would probably get charged more for labor to replace those batteries than replacing the entire sensor depending on how much they charge you for the battery. You would def need more than just a battery and o ring as you have to scrape out all that filler stuff and reapply if after your manage to swap out the battery
| The Following User Says Thank You to saltywetman For This Useful Post: | suppjc (04-06-2022) |
#5 | |
Thanks! |
#6 | |
Thank you. |
#7 | |
Thank you! |
#8 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
You are probably good for at least another 3-5 years on your current set. Wait till your next tire purchase.
| The Following User Says Thank You to 2020BRZtS For This Useful Post: | suppjc (04-07-2022) |
| Battery replacement oem | Silverz | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-31-2023 12:36 PM |
| Battery Leaking - 4th Replacement | djrbash | Issues | Warranty | Recalls / TSB | 23 | 02-15-2021 12:16 AM |
| Replacement Battery | jasonojordan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 17 | 01-24-2017 07:15 PM |
| Car Audio Battery Replacement | brzstormtrooper | Electronics | Audio | NAV | Infotainment | 0 | 03-23-2016 08:38 AM |
| Replacement Battery | slizoth | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-09-2014 03:04 PM |
