Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#29 | |
Drives: Black FRS
Did not get any coilpack CELs when it was misfiring. Just misfire CEL on specfic cylinders. |
#30 |
Drives: 2013 Subaru BRZ
A throttle reset appears to have everything mostly back to normal. Thank you guys for the suggestion, I would have never have thought of that.
Now that I have throttle, car runs superbly with new plugs and IP coils. Acceleration is smooth and improved. I am very pleased so far. I also notice quite a noticeable reduction in valvetrain noise. I will post if I have issues with the IP quads, but happy so far here at the start. |
#31 |
well this sucks. Was kinda hoping the hood vents would help fix this. So far I have only had the code for the CP on the passenger front one. PITA to replace these. When it goes out I can trigger the code every time at the top of 4th. Normal driving is just fine.
2013 Series 10 FRS #553
#32 |
First 86 Driver Baby!
Drives: FR-S, Flex
Well I have a possible CP issue now. The past couple of days I've gotten a flashing CEL when going WOT at highway speeds in 4-6th gear. It'll go out after anywhere from 5-10ish flashes. There's also a little studder/hesitation when I first try to get on it. Yesterday on my way home from work It stayed on. I checked the code when I got home and it's a P0301 (cylinder 1 misfire detected). So I swapped the #1 & 3 CPs to see if I can get the code to move to cylinder 3. I didn't drive the car again until today on my way to work. I was able to get the flashing CEL, but not steady yet. I'l try again on my way home. If that doesn't work, any thoughts on what else it could be?
Details on my car: it's a 2013 FRS, 107K miles, of which 105K have been boosted. |
The Following User Says Thank You to kmbkk For This Useful Post: | jeepmor (09-08-2022) |
#33 |
Drives: '13 FRS - STX
fuel air spark
I'd guess if it's not spark plugs/coil packs it'd be injectors. Did you replace the plugs at 60k miles? |
#34 |
Drives: GT-86
#35 |
#36 |
Drives: GT-86
#37 |
Drives: unlimited cheap build N/A track car
Here is a little bit of gold for everyone having coil pack issues. I hate to see all the suffering and money wasted replacing coil pack, especially people thinking they need high dollar ones.
I had been throwing miss fire codes on both banks intermittently for many track days. I would just clear the code and continue. It got progressively worse so I decided to investigate. The problem is the electrical plug at the coil pack. It is poorly designed and the electrical connection is not great. I decided to do an experiment and tweeked the male pins on the coil pack with needle nose pliers. I just twisted them 10 degrees or so to preload the connection and put them back on the car. Its been about a year (5 or 6 track day weekends) and I have not had another issue. I hope this works as well for you guys as it did for me. |
#38 | |
Drives: Dodge Patitas
Can you provide a bit more info regarding the circumstances? Heavy track use, for example?
![]() ![]() Last edited by sato; 02-14-2022 at 03:53 PM. Reason: Additional quote |
#39 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
I have an Edelbrock SC and just got a P0301 I want to try your trick with the coil pack electrical plug change. Did you take any pics when you tried that?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#40 |
Drives: GT-86
#41 | |
#42 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. |
IP Coil Packs | bozack | Engine, Exhaust, Transmission | 6 | 03-06-2022 01:36 PM |
2013 Coil Packs, where did you guys get them from? | Keenercarguy | Issues | Warranty | Recalls / TSB | 24 | 05-25-2018 08:43 PM |
Stock 13/14 coil packs | shaynek | Want-To-Buy Requests | 1 | 04-26-2018 08:20 AM |
Do I have bad coil packs or a failing DI pump? | xkalelx | Forced Induction | 16 | 03-15-2016 01:56 PM |
Vendors/Members, Anyone have coil packs in stock? | ZionsWrath | Engine, Exhaust, Transmission | 3 | 05-12-2015 02:04 PM |
