Drives: 2018 BRZ
Performance Package Dust Cover / Shield
Is the dust cover the same for the Brembo's on the Performance Package (2018) as they are for the standard OEM brakes. Researching part numbers it appears so, but knowing the disk is bigger and seeing how it fits with the standard disk makes me think that could be wrong. I appreciate any help from anyone with experience with this situation!
#2 |
Drives: Chevrolet Ram 250
I don't think they'd physically be the same since you'd have to modify the non PP dust covers to get larger rotors to fit.
I got a smooth brain.
#3 |
Drives: 2018 BRZ
#4 | |
Wheels for Brains
The PP Dust shields are physically larger than the Base dust shield to accommodate the larger rotors. They have distinct part numbers for each set. I swapped out to PP Dust shields when I installed my BBK. Often, people elect to remove their front dust shields out of convenience (and potentially improved cooling). When people say they "modify" the base dust shields to get a BBK to fit, they usually refer to the rear dust shields. Some people elect to just trim the rear dust shield as a matter of convenience, since to replace the rear dust shield requires removing the parking brake assembly, slip the rear axle away, and remove it from the rear wheel hub IIRC. Since the rear dust shield is pretty much the carrier for the parking brake, they are pretty expensive (~$90 each new) compared to the front dust shields (~$20 each) Last edited by EndlessAzure; 03-19-2022 at 03:10 AM. |
#5 | |
Drives: 2020 Toyota 86 GT 6M
The rear dust shields are spot welded on IIRC unlike the fronts that are bolted on. Removing the assembly would make modifying the rear shields much easier to trim the edges so the larger rotors would fit though. I'm not aware of after market dust shields for the rears that are bolt-ons
#6 | |
Wheels for Brains
The dust shield on its own is not sold as a separate component. You need to order a whole parking brake carrier with integrated dust shield. You can replace the whole base parking brake carrier for a PP parking brake carrier (the major difference being the diameter of the welded-on dust shield). This is why the "rear dust shield" is so expensive and involved to get to. You're replacing the entire carrier. Obviously, this only works if the BBK system you're installing matches the rear PP disk diameter. If you're installing a larger/different system, cutting it off might really be your only choice. (The same can be said of compatibility for the front PP dust shields if your BBK system rotor doesn't match in diameter.) |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | saltywetman (03-22-2022) |
#7 | |
#8 | |
Drives: 17 BRZ
#9 |
this is with the park brake assembly? so it's exactly the same between normal and PP editions?
#10 |
| Stabilizer link dust shield | Masacur | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 11-04-2019 11:22 AM |
| Transmission dust cover? | number_Un0 | Issues | Warranty | Recalls / TSB | 13 | 02-07-2017 04:01 PM |
| Parking brake dust cover | Chaetagnath | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 08-29-2014 11:05 PM |
| changing idler pulley from vortech, dust cover? | Sniper2606 | Forced Induction | 0 | 02-01-2014 04:02 PM |
| 3M Paint Protection Film and Vehicle Shield Package? | garsh0p | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-13-2012 12:13 PM |
