Old 03-17-2022, 06:31 PM   #1
zac8
zac8's Avatar
Drives: 2018 BRZ tS black and 2007 impreza
Perceived power decrease as engine/oil temp raises
I've been noticing this for over a year now with my JRSC.
There seems to be no correlation with outside temps or driving style. Street use only. Tuned by Delicious Tuning. Using 5w30 oil.
Lets say I've been driving for 10 minutes. The car is pretty warmed up. If I give it some throttle it really wants to go. Now 30 minutes goes by, the engine/oil temp is where it normally sits (about in the middle of the stock gauges), I give it some throttle and it wants to go slightly less. Also more noticeable on the highway.
Sorry about the lack of description/numbers. I just can't figure out why it seems to feel like this. Is it just me? Is it something with the temps? Is it something with the tune or computer that's slowing it down?
Maybe somebody else has experienced something similar.
Any help/brainstorming is appreciated!
zac8 is offline   Reply With Quote
The Following User Says Thank You to zac8 For This Useful Post:
humfrz (03-18-2022)
Old 03-17-2022, 06:49 PM   #2
Ashikabi
Ashikabi's Avatar
Could be your intake temps being elevated. Or you'll run slightly richer the cooler the engine is. So you might make slightly better power then. I'm not sure how you are tuned or what your temps look like
Sent from my ONEPLUS A5010 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
NoHaveMSG (03-18-2022), RToyo86 (03-17-2022)
Old 03-17-2022, 07:06 PM   #3
zac8
zac8's Avatar
Interesting idea. The only thing I do with the tune is log it haha so neither do I. But the temps seem to be all normal. I can run this by my brother, hes a mechanic. Thanks!
Old 03-17-2022, 08:48 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Sounds like heat soak. Check Intake Air Temperature (IAT) and if the engine is pulling timing. Might need more engine bay cooling/ventilation if you want to avoid that
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
zac8 (03-17-2022)
Old 03-17-2022, 08:49 PM   #5
tomm.brz
Drives: brz 2017 hksv2
doesn t really make sense, this car goes faster the leaner is, with the same ignition timing... so that s probably something that makes it richer and maybe lowers ignition timinga as the temp raise
Old 03-18-2022, 03:09 AM   #6
- there ya go, all better now?
Old 03-18-2022, 06:52 AM   #7
Steve Bodalenko
Drives: 2013 Harrop Toyota 86
This will be the issue. Under hood temps after the car is fully warmed have climbed. Any car will always run better when the IAT is cool and the charge is dense.
Steve Bodalenko is offline   Reply With Quote
The Following User Says Thank You to Steve Bodalenko For This Useful Post:
zac8 (03-18-2022)
Engine Oil Temp Kayysonie Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-29-2015 10:29 AM
BRZ has a higher perceived value ? irax BRZ First-Gen (2012+) — General Topics 27 01-09-2015 01:20 PM
Will Helmholtz resonator decrease power? shu5892001 Engine, Exhaust, Transmission 31 01-07-2015 10:37 AM
How to tell Engine's Operating Temp? tez2013 Tracking / Autocross / HPDE / Drifting 9 06-03-2013 02:33 AM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 11:52 PM
