Old 03-09-2022, 06:57 PM   #1
Turdinator
Señor Member
Turdinator's Avatar
Manual gearbox breather
I think my gearbox breather might be blocked. Does anyone have experience replacing or cleaning theirs? On the manual not automatic gearbox.
1974 TA22 Celica
2013 86 GT
Old 03-09-2022, 07:30 PM   #2
I don't believe that the MTs in these have a vent/breather.
Old 03-09-2022, 07:57 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is a breather between the reverse and neutral position switches. It is pressed into the case though and does not look like it is removable through non-destructive means.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (03-09-2022), Tcoat (03-10-2022), Turdinator (03-14-2022)
Old 03-10-2022, 09:39 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Just curious. What symptoms are you having?
Old 03-10-2022, 10:59 AM   #5
Ya I looked through the service manuals and they don't even show it as existing much less have a repair/replacement procedure for it.
NoHaveMSG (03-10-2022)
Old 03-10-2022, 01:03 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Makes sense as it looks for sure non serviceable. The main body is pressed in and the cap is crimped at the base. It feels like there is a spring in there that keeps the cap up. You may be able to pry the cap off and re-crimp it but
OP, I'd gently blow air into the fill hole in a non-sexual manor and see if you can feel air venting around the cap.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-10-2022), Decep (03-10-2022), norcalpb (03-10-2022), Turdinator (03-14-2022), Ultramaroon (03-14-2022)
Old 03-10-2022, 01:54 PM   #7
blsfrs
blsfrs's Avatar
If you pull that sensor out could you see where the inside of the vent is with a bore scope? Another option would be to blow smoke from a smoke machine into the fill whole. It would be slightly less erotic than what @NoHaveMSG described.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (03-10-2022), norcalpb (03-10-2022), Ultramaroon (03-14-2022)
Old 03-14-2022, 05:23 PM   #8
Curious about the symptoms. Is it leaking fluid out either end?
blsfrs (03-14-2022)
Old 03-14-2022, 07:10 PM   #9
Grady
Grady's Avatar
Not 100% sure but do not think it is a breather. I believe it is a over/under pressure valve. Not vented to atmosphere but there to relieve pressure if needed.
The Following User Says Thank You to Grady For This Useful Post:
blsfrs (03-14-2022)
Old 03-14-2022, 07:29 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's for sure a breather. Without it we would be losing seals. You can move it open/closed with very little effort. There is one just like it on the diff too. Gravity basically holds in closed and any positive pressure due to heat won't need much force to open it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-14-2022), Ultramaroon (03-15-2022)
Old 03-14-2022, 11:31 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
The rear seal is leaking even after installing a new oem seal. The yoke has no significant wear, just a little polished. I seem to remember there being some vacuum when I last undid the refill bolt also. It may be something more serious but the breather seemed like an easier place to start.
If its not replaceable I will look at doing that.
Firstly... How I treat my gearbox is between me an the box... This is not the place for kink shaming..
Secondly this is not a bad idea also.
1974 TA22 Celica
2013 86 GT
The Following 3 Users Say Thank You to Turdinator For This Useful Post:
blsfrs (03-15-2022), NoHaveMSG (03-15-2022), Ultramaroon (03-15-2022)
Old 03-15-2022, 01:08 PM   #12
The breather is a check valve. The spring is between the cap and a ball. As observed at ambient temp, the transmission should maintain a slight vacuum.
AVO Breather Tank for Turbo RKirklin Forced Induction 31 03-16-2018 11:18 PM
Jeremy Clarkson Slams The Manual Gearbox – Could He Be Right? Darth Khan Off-Topic Lounge [WARNING: NO POLITICS] 15 09-06-2017 10:49 PM
Honestly how is the manual gearbox in comparison to the other options? Whodunit Engine, Exhaust, Transmission 38 04-10-2016 06:54 PM
AVO Breather Tank, caution Ironsquid User/Vendor/Sponsor Reviews, Feedback, Comments 3 02-17-2014 08:11 PM
Questions on AVO Breather Kit? BenArmstrong Engine, Exhaust, Transmission 7 09-17-2013 04:01 AM
