Old 07-21-2021, 07:59 AM   #183
Ashikabi
Ashikabi's Avatar
Originally Posted by kurty85 View Post
Well the smoking is back. Drove the car for 30 minutes today. Checking data logs I had 76 psi of oil pressure at 3600 rpm. Wondering if a smaller restrictor is needed or need to check the seals on the turbos?
I can get you a set of hood vents. I'm also working on a big radiator kit if you're interested in that
Sent from my ONEPLUS A5010 using Tapatalk
Old 07-21-2021, 08:24 AM   #184
kurty85
Drives: 2014 FRS LS Swap
Definitely would love to get some hood vents from you. Already have a huge radiator. I cut off the mounts and made new mounts. Becool 35202 26.5x19.5.
Sent from my SM-G973U1 using Tapatalk
kurty85 is offline   Reply With Quote
Old 07-21-2021, 08:25 AM   #185
Ashikabi
Ashikabi's Avatar
Pm me whenever you're ready
Old 07-23-2021, 10:10 AM   #186
all4spl
I'm located in Chesapeke and work in Norfolk. If you ever need anything, I can supply you with parts and engine building labor / parts to get things where you want them to be!
all4spl is offline   Reply With Quote
Old 07-23-2021, 10:15 AM   #187
kurty85
awesome. thanks man.
Old 07-23-2021, 10:51 AM   #188
StraightOuttaCanadaEh
Wes
Holy hell what a monster. Congrats on the build!
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
kurty85 (07-23-2021)
Old 03-11-2022, 10:01 PM   #189
kurty85
Update: Tore apart the front end to fix the smoking issue with the turbo oil drains. Turns out one of the drains was being blocked by the oil windage pipe behind the drain boss and the other line was slightly kinked. I relocated the bosses to the sides of the pan and verified nothing is blocked. I also rebuilt the turbos with all new piston rings, O-rings, and bearings. I changed the drain line to a full 5/8 rubber hose and used precision high flow turbo oil drain fittings with no gaskets, only O-rings. I figured while I was doing all this work, I moved the radiator forward and made more room for the top radiator hose. I also swapped the cam with a BTR stage 2 turbo cam, 7.4" .080 wall solid BTR pushrods, and changed out the rocker arm trunnion bushings with solid brass bushings. Tapped the driver's side valve cover for a -10 vent and used the passenger's side with a -10 to oil fill adapter, all going to a -10 catch can with breather. I also added a 4 port steam vent kit from motion race works with top bleed fitting. Almost everything is reassembled, hoping to startup this weekend and test the turbo drains, then start tuning again. Being back in the states is awesome for getting parts compared to Guam!
Old 03-13-2022, 12:27 PM   #190
all4spl
any pictures?
Old 03-13-2022, 07:34 PM   #191
kurty85
Just took these. Need to finish the driver's side ic pipe and I can start.
Old 03-13-2022, 07:43 PM   #192
kurty85
Also ordered some stainless material to make heatshields for the coils. Kind of like the Dai Yoshihara LS7 FRS.
Old 05-01-2022, 06:53 PM   #193
kurty85
Working on swapping gears to a 3.58 r&p. Got the ring gear mounted, case torn down, ready for powdercoat. Waiting for nitro gear 8" toyota rebuild kit and 1350 pinion upgrade to set bearing preload, pinion depth, backlash, and carrier preload. Going with a solid pinion spacer and upgraded axles. Anyone know the easiest way to remove the bushings in the case?
Old 05-01-2022, 10:10 PM   #194
Ashikabi
Ashikabi's Avatar
How much is that costing you?
Old 05-02-2022, 03:44 PM   #195
kurty85
Roughly 800 for everything minus 1350 flange upgrade. Still deciding on that due to different ds needed.
Old 05-02-2022, 04:44 PM   #196
Ashikabi
Ashikabi's Avatar
That's not bad... That's what an IS300 diff costs and this has better gearing
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Not just another ls swap killin'_for_a_livin' Member's Car Journals 7 08-28-2016 05:58 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 07:29 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
