Old 03-09-2022, 03:17 PM   #1
Christian628
Drives: 2013 Scion FRS
Deciding on coilovers and springs
Anyone have any experience with Silvers Neomax coilovers on a frs or brz? I was trying to decide between Fortune Auto and RSR and saw someone on another forum say Silvers is Fortune Autos supplier. Tried to find a review of them for our cars, but came up empty. Also trying to decide if swifts would be worth it just for daily driving. And please dont recommend ST of some V3s. Looking for coilovers that adjust by a rotating bottom bracket.
Christian628 is offline   Reply With Quote
Old 03-09-2022, 03:20 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What are you doing with the car? Street car hitting back roads, track car, autoX?
Old 03-09-2022, 03:57 PM   #3
Christian628
Daily driving. Occasionally some spirited backwoods corners with some friends. But I dont really give it hell. Most of the corners you cant see around and they are thin roads.
Old 03-09-2022, 04:09 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd just go with RCE yellows with B6's. Retain the stock top hats and get some camber bolts.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
Captain Snooze (03-10-2022), jeepmor (03-17-2022), N_Raged (03-11-2022), RippedManiac (03-17-2022), x808drifter (03-10-2022)
Old 03-09-2022, 04:22 PM   #5
Christian628
Id like to drop somewhere around 2-3 inches. So I want to go with actual coilovers. I want something that I can rebuild so they last a while. Thats why I was looking at the fortune auto, rsr, and silvers. Any experience with these or something comparable?
Old 03-09-2022, 04:38 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At 2-3 inches of drop you are going to have very little bump travel and any coilover is going to ride terribly. I'd just go with cheap if you are looking to go that low.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
jeepmor (03-17-2022), norcalpb (03-09-2022), x808drifter (03-10-2022)
Old 03-09-2022, 08:05 PM   #7
norcalpb
norcalpb's Avatar
Don’t the STs adjust with a rotating bottom bracket? But just one instead of two.
All the coils you mentioned I believe are manufactured by Bor Chun (BC Racing) but rebranded and slightly modified. They are not bad on a smooth track, but you may find them lacking in the street comfort category. Basically the high speed damping is pretty good but the low speed damping can be brutal.
I would personally look at Tein flex Z/A/CSG A, or if you end up being OK with ST’s, RCE and Greddy both have tuned variants for the 86.
But as @NoHaveMSG said, you may be best off getting a sport shock like the Bilstein B6 which is honestly pretty firm (in a good way) and will last you longer than the struts/shocks of all the aforementioned coilovers. Plus you can choose whichever spring you want to go with it. If you really do want to drop 2-3” I would choose the Bilstein b8 to keep a short lowering spring fully captive at all times.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 03-10-2022, 06:20 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
How to screw up your cars handling and ride - step by step!
3. Big drop on lowering springs
If it looks a racecar then it must handle like one, right? Unfortunately, it doesn't exactly work like that. A little drop can improve things with proper spring rates, but past an inch or more and you start making big compromises and riding the bumpstops before you even hit a bump. It's a sure way to downgrade your handling. Aftermarket shocks may help in some ways, but don't solve the travel problem.
4. Big drop on coilovers
With some coilovers you don't need to worry about bump travel as much, but geometry is still a concern when lowering 2 inches. A big change in roll center height and changes in the dynamic alignment can be felt from the driver's seat...and it feels sloppy.
I know what you're thinking. There are a ton of cars on here that hit the track and handle well with a lowered ride height. If you must have that really low center of gravity than you must use very firm spring rates (and then quality dampers to match) or use geometry correction parts. That's what the fast guys and girls at the track are doing....not slamming their crappy coilovers to the ground and expecting all to be well.
From
https://www.ft86club.com/forums/showthread.php?t=67345
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
jeepmor (03-17-2022), nathand (03-17-2022), Racecomp Engineering (03-10-2022), x808drifter (03-10-2022)
Old 03-10-2022, 07:54 AM   #9
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Not a lot of coilovers are engineered for a 2-3" drop (due to the negative consequences mentioned above), but you're already looking at some of the few brands that do. So if you're dead set on going that low...
The RS-R Black-i have had favourable reviews on this platform (not to be confused with their Sports-i model, which is the more performance-oriented/moderate lowering model). And rather than typical pillowball top mounts, they use urethane bushings in their top mounts, so they probably have less NVH than the others. They're made in Japan, always had a good reputation, and been around since the 1980's.
Some reviews on this platform:
https://www.ft86club.com/forums/showthread.php?t=49980
https://www.ft86club.com/forums/show....php?p=1120073
https://www.ft86club.com/forums/show....php?p=1423221
The Fortune Auto SuperLow Spec comes with Swift springs as standard...unless you're looking at the regular 500 Series. The 500 Series they may not achieve the 2-3" drop you're looking for (I've read they don't go very low on this platform). However, the SuperLow Spec seems to be new, haven't seen any reviews about them...
I briefly researched Silvers Neomax in the past and also didn't find any reviews for this platform. Only found reviews on other platforms and that they're made in Taiwan (probably by BC Racing as mentioned above). I also recall reading somewhere that they are a supplier for Fortune Auto.
Due to the lack of experience/reviews of Silvers Neomax on this platform, you might be the guinea pig too if you go this route. And worth contacting them to see if their standard kit can even lower this platform 2-3". And their site doesn't mention what the "Super Low Kit" option entails, so probably worth asking about that too.
Whether Swift springs are worth the upgrade are subjective on a car that doesn't see a track/hard driving...maybe if you're keeping the car/coilovers long-term? They've got a reputation for maintaining consistent spring rates and performance (reaction speeds and travel).
The Following 2 Users Say Thank You to NLSP For This Useful Post:
jeepmor (03-17-2022), smackrel (01-26-2026)
Old 03-10-2022, 09:42 AM   #10
Christian628
This is exactly the kind of response I was wanting! Ive read the post about ruining the car a while back and have a couple of comments and questions about some things said. Will update soon. Thank you so much.
The Following User Says Thank You to Christian628 For This Useful Post:
NLSP (03-10-2022)
Old 03-10-2022, 10:58 AM   #11
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Just to add something not mentioned above is that when you go lower than 1", you also run the risk of damaging your CV joints (rear Axles) in the long run.
So going that low is not recommended.
Thefalls is offline   Reply With Quote
The Following User Says Thank You to Thefalls For This Useful Post:
Wally86 (03-10-2022)
Old 03-10-2022, 11:13 AM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
A friend runs silvers with a 255 squared RS4 setup.
Car feels great on the road, though he is maybe lowered 1 1/2 inches, 2 max.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 03-10-2022, 11:20 AM   #13
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Without a diff riser kit to fix the axle angle?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Thefalls (03-10-2022)
Old 03-10-2022, 12:14 PM   #14
Christian628
Is there one good for not adding a ton of nvh?
JDM TRD Springs / Coilovers vs USA TRD Springs darksnyder Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-12-2019 10:11 PM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 03:49 PM
Need help deciding coilovers! 2JZ-GTE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 08-03-2015 06:17 PM
Springs or coilovers? cooldandani Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-08-2014 03:43 AM
Springs or coilovers. Itssrayyxd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 04-26-2013 09:32 AM
