Señor Member
Manual gearbox breather
I think my gearbox breather might be blocked. Does anyone have experience replacing or cleaning theirs? On the manual not automatic gearbox.
1974 TA22 Celica
2013 86 GT |
#2 |
I don't believe that the MTs in these have a vent/breather.
#3 |
Drives: Crapcan
There is a breather between the reverse and neutral position switches. It is pressed into the case though and does not look like it is removable through non-destructive means.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#4 |
Drives: 2013 frs base
#5 |
Ya I looked through the service manuals and they don't even show it as existing much less have a repair/replacement procedure for it.
| The Following User Says Thank You to Tcoat For This Useful Post: | NoHaveMSG (03-10-2022) |
#6 | |
Drives: Crapcan
![]() OP, I'd gently blow air into the fill hole in a non-sexual manor and see if you can feel air venting around the cap.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (03-10-2022), Decep (03-10-2022), norcalpb (03-10-2022), Turdinator (03-14-2022), Ultramaroon (03-14-2022) |
#7 |
If you pull that sensor out could you see where the inside of the vent is with a bore scope? Another option would be to blow smoke from a smoke machine into the fill whole. It would be slightly less erotic than what @NoHaveMSG described.
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
#8 |
Curious about the symptoms. Is it leaking fluid out either end?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (03-14-2022) |
#9 |
Not 100% sure but do not think it is a breather. I believe it is a over/under pressure valve. Not vented to atmosphere but there to relieve pressure if needed.
| The Following User Says Thank You to Grady For This Useful Post: | blsfrs (03-14-2022) |
#10 |
Drives: Crapcan
It's for sure a breather. Without it we would be losing seals. You can move it open/closed with very little effort. There is one just like it on the diff too. Gravity basically holds in closed and any positive pressure due to heat won't need much force to open it.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (03-14-2022), Ultramaroon (03-15-2022) |
#11 | |||
Señor Member
Secondly this is not a bad idea also.
1974 TA22 Celica
2013 86 GT |
| The Following 3 Users Say Thank You to Turdinator For This Useful Post: |
#12 |
The breather is a check valve. The spring is between the cap and a ball. As observed at ambient temp, the transmission should maintain a slight vacuum.
| AVO Breather Tank for Turbo | RKirklin | Forced Induction | 31 | 03-16-2018 10:18 PM |
| Jeremy Clarkson Slams The Manual Gearbox – Could He Be Right? | Darth Khan | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 09-06-2017 09:49 PM |
| Honestly how is the manual gearbox in comparison to the other options? | Whodunit | Engine, Exhaust, Transmission | 38 | 04-10-2016 05:54 PM |
| AVO Breather Tank, caution | Ironsquid | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 02-17-2014 07:11 PM |
| Questions on AVO Breather Kit? | BenArmstrong | Engine, Exhaust, Transmission | 7 | 09-17-2013 03:01 AM |
