Old 02-11-2022, 08:07 PM   #1
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Twin Supercharger FRS
Hey guys, here's an intro video to my custom twin supercharger build that I did on my FRS.
I'll be adding a more detailed build video or videos here in the future.
Jaden
Jaden is offline   Reply With Quote
Old 02-11-2022, 08:41 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Dude that thumbnail is terrifying.
Subbed though.
Old 02-12-2022, 08:05 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
So much facial hair.
Interesting mod.
Old 02-13-2022, 07:12 PM   #4
Lantanafrs2
Drives: 2013 frs red
Stuff like this usually comes from Australia lol
Lantanafrs2 is offline   Reply With Quote
Old 02-17-2022, 02:45 PM   #5
p1l0t
p1l0t's Avatar
Can't wait for the rest to drop! How are you tuning it/going to tune it? (I know you may need other parts before the final tune based on the video).
Old 02-17-2022, 08:44 PM   #6
Jaden
Road-hole
Yeah, already had the part.
I got the tune from Steve99 here on the forums. So the problem is that it is running rich. I thought it might be an issue with the fuel pump module and the regulation of voltage to the fuel pump because a while back mine failed and I ended up upgrading to an AEM 340lph pump that I connected directly to switched 12v.
A While ago I had bought a replacement fuel pump module but never installed it back in and wired the fuel pump back to it to verify that was actually the problem.
Two days ago I went ahead and put it in and wired it up, verified that the fuel pump worked again going through the fuel pump module and soldered and shrink wrapped everything back up.
I tested it and it's still running rich. I compared some logs and it appears that the percentage of ethanol is showing higher, (never had the logging parameters to show what the ECU was showing for ethanol content until Steve just sent them to me a couple of weeks ago), than the custom arduino that I programmed to convert the signal from the GM ethanol content sensor to voltage was showing.
So at this point I'm trying to figure out where that problem lies, in the arduino programming or in the tune conversion.
The arduino was showing about 4% less ethanol content than the logging was showing from the ECU. Which is really about a 20% discrepancy at lower ethanol percentages. 23% in the ECU versus 18-19% in the arduino.
I'm pretty sure once I get that part fixed, it will run correctly. We'll see. I'll work through whatever I have to.
I also have an ecutek that I can always use. I'm tuning with an tactrix openport to try to see what type of performance per dollar it's possible to get.
As the car sits right now performance wise, I have about a total (aside from the cost of the car) of about $1500 invested. That includes the twin superchargers, the flex fuel, all tuning, perrin intake, full exhaust, etc. I have lowering springs, whiteline front adjustable camber bolts, rear LCAs (tire wear is crazy fast once you lower these cars without those).
Jaden
p.s. You can expect that cost to go up quite a bit more to get tires that will get me traction now...lol
Old 02-28-2022, 12:46 PM   #7
p1l0t
p1l0t's Avatar
Custom Ardruino... you are the man! I love programming/electronics and I love wrenching on cars but I've actually never crossed the two hobbies.
Twin Supercharger? nelsonzep Scion FR-S / Toyota 86 GT86 General Forum 1 06-29-2015 07:54 PM
Sprintex Innovate Twin Screw supercharger Intercooled kit Bluetail Engine, Exhaust, Bolt-Ons 23 05-20-2015 03:41 PM
Gauging interest on a twin-screw supercharger kit!!! Argento_FR-S Forced Induction 27 06-19-2013 08:35 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
Exhaust to go with twin screw supercharger diss7 Forced Induction 25 03-04-2013 06:17 PM
