| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Issue with Direct Fuel Assy Injector BRZ / FT86 2013 P1261/P1264
i have 2 car
1. BRZ 2013 ( All Stock Part , No Upgrade ) 2. FT 86 2012 ( All Stock Part , No Upgrade ) At November 2021 , my BRZ have Problem P1261 P1261 code possible causes
I try to switch injector between 1 and 3 but still got P1261 Resume is , Not Broken Injector Desember 2021 : I try to switch ECU from FT86 , Error Still P1261 Resume is , Not ECU FAILED I Buy 1 set Engine Full Harness still got P1261 Resume is : Not Cable Problem I Buy Electronic Control Module ( one inside pessenger seat ) still got P1261 Also I try to Install BRZ ECM to FT86 , FT86 Normal Resume is , Not ECM FAILED At January 2022: I take Of the machine from car , and see any problem , but can't get problem , all normal Put in the machine back ERROR go to P1264 I take off 4 injector , part Number of injector is SU003-04462 same as installed in both my car I buy 1pc from toyota dealer and put in on Di Injector 4 The Error Change to P1261 I Buy 1pc Again From Toyota Put it in Port 1 The Error Goes to P1262 I Buy 1pc MORE From Toyota Put in on Port 2 The Error Go BAck to P1264 February 2022 : I try to switch 1 set ( 4pcs ) injector from FT 86 to BRZ The BRZ Normal FT 86 Problem P1264 , I try combination of ALL Injector that i have ( 3pcs new injector + 4pcs used injector ) the problem exist........... I dont know anymore , what i have to do ..... Anyone can help my problem please......... |
#2 |
Drives: 2013 frs base
The DI controller is mounted on the right side of the engine. The bottom bolt is the ground. Are all the engine grounds connected?
#3 |
SOLVED ,.... i try to mix , 3pcs new injector + 4pcs used injector
4pcs of injector , Must be same Voltage 2 of them is diffrent ( broken ) |
| The Following User Says Thank You to akumahasansaid For This Useful Post: | blsfrs (02-27-2022) |
| Tags |
| assy, fuel, injector |
| FS MT Direct Injector Ecu 23k before removal | Darth | Engine, Exhaust, Bolt-Ons | 2 | 02-06-2019 03:26 AM |
| OTC Direct Fuel Injector Seal Installation Tool | EWY | Engine, Exhaust, Bolt-Ons | 6 | 08-26-2017 10:05 PM |
| Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 0 | 01-07-2014 01:13 PM |
