Old 02-08-2022, 03:43 PM   #1
Strat_FRS
Drives: 2015 FRS for daily and track use
Ice Racing and diff swap? I think you should :)
Racing or autox on a frozen lake is a special kind of pleasure. Relatively low risk while being sideways more often than straight. Car control turned up to 11 and fun up to 12.
We put in a plated differential in the FRS along with a shorter final drive (4.44:1) for this event and the plated differential in these low traction conditions does make a lot of difference. It is so predictable when locking up.
I've had this experience in a number of cars and while the Torsen is much better than an open diff or a viscous one, plated makes that experience and rear end control that much better.
Enjoy some pictures from the event. Placed second for the rubber RWD class. I am also preparing a video of the diff swap and event.
Strat_FRS is offline   Reply With Quote
The Following 5 Users Say Thank You to Strat_FRS For This Useful Post:
Arthur-A (02-08-2022), bcj (02-09-2022), fminicooper (02-08-2022), NoHaveMSG (02-08-2022), ZDan (02-08-2022)
Old 02-08-2022, 04:18 PM   #2
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
By plated you mean clutch type?
Arthur-A is offline   Reply With Quote
Old 02-08-2022, 06:42 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I always disliked the stock Torsen for ice racing.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
soundman98 (02-08-2022)
Old 02-08-2022, 08:31 PM   #4
Strat_FRS
Yes, a Kaaz 1.5 way LSD
The Following 2 Users Say Thank You to Strat_FRS For This Useful Post:
Rear diff swap from 4.10 to 4.30 SockMonkey Engine, Exhaust, Transmission 28 08-29-2021 12:03 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 03:59 PM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 09:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 12:05 PM
