Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-24-2022, 08:37 PM | #16 |
Seņor Member
Why bolts when all the damage is in the middle? Not saying anyone is wrong, just trying to learn something.
1974 TA22 Celica
2013 86 GT |
The Following 2 Users Say Thank You to Turdinator For This Useful Post: | soundman98 (01-24-2022), Wally86 (01-25-2022) |
01-24-2022, 10:56 PM | #17 | |
chicken tonight
Whole lotta guesswork based on those pics.
01-25-2022, 08:47 AM | #18 | |
Drives: 2013 frs base
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | Ultramaroon (01-25-2022), Wally86 (01-25-2022) |
01-25-2022, 08:52 AM | #19 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following 4 Users Say Thank You to Ashikabi For This Useful Post: |
01-25-2022, 04:28 PM | #20 | |
chicken tonight
Shit breaks. Super lucky it was on the dyno.
01-25-2022, 05:57 PM | #21 |
Close up pictures of the fracture could give us a clue if a crack progressed into a failure or it just failed. Plus you need to look at the scoring at the failure point. It almost looks like the scoring came before the failure.
The Following User Says Thank You to Grady For This Useful Post: | blsfrs (01-26-2022) |
01-25-2022, 06:02 PM | #22 |
chicken tonight
Yup. Chicken <-> Egg
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (01-26-2022) |
01-25-2022, 06:22 PM | #23 |
Drives: Scion FR-S 10 Series
I am glad it didn't happen on the street, this just reinforces my notion of putting a safety loop when going to an aftermarket one piece drive shaft.
The Following User Says Thank You to Jdmjunkie For This Useful Post: | blsfrs (01-26-2022) |
01-25-2022, 06:51 PM | #24 |
01-25-2022, 06:54 PM | #25 |
Dismember
Drives: 2013 Red Scion FR-S
Many bolts are designed to deform in specific ways when tightened. If they're pulled out and then put back in, they no longer meet the spec and can have issues. Tesla recently had a recall over this, with factory workers torqueing, loosening, then retorquing. The bolts needed to be taken completely out, replaced, and torqued properly ONCE.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | blsfrs (01-26-2022), Ultramaroon (01-25-2022) |
01-25-2022, 07:16 PM | #26 |
Drives: Crapcan
I've probably pulled and reused the driveshaft bolts about 6 times on my car Always German torque. I should probably buy a crows foot and do it proper.
Edit: Now that I think about it a bit harder, it is probably more like 12 times.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
01-25-2022, 08:50 PM | #27 |
Drives: 2015 FR-S
Turning it 4 times to try to get rid of vibration is def PITA having to get new bolts each time. But also there were a couple of threads a while back about the bolts being too short with aftermarket shafts and results in only half your nuts thread engaging. Solution was to get longer bolts so that all threads engage. I still haven't done it yet on mine @blsfrs do you remember if all the threads engaged on yours?
01-26-2022, 03:36 AM | #28 | |
Dismember
But that 1/1000 is bad enough for a safety recall. 1/1000 * 100,000 cars is 100 failed cars that could kill people in the first year. And then the car companies look at a car's life over 20-30 years, and they start to sweat, because that 100 failures can become 10,000 or more if things go badly. Hence we get our valve springs recalled. But you? In a car you probably inspect often? Fuggetaboutit.
The Following User Says Thank You to EAGLE5 For This Useful Post: | blsfrs (01-26-2022) |
Similar Threads | ||||
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) | Lefty-FRS | Transmission and Driveline | 13 | 02-09-2018 10:02 PM |
OEM drive shaft | Baramzisyan | Transmission and Driveline | 13 | 03-22-2014 03:25 PM |
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 01:40 PM |
