Old 01-19-2022, 08:34 AM   #15
02maher
02maher's Avatar
Drives: Gt86 2013
K that's pretty clear. You are running 91+fuel right?
Sent from my ONEPLUS A5010 using Tapatalk
Indeed, we only have 95 and 98 here both make no difference either
02maher is offline   Reply With Quote
Old 01-19-2022, 08:38 AM   #16
Ashikabi
Ashikabi's Avatar
Jesus, 98? You're not in America are you?
You could try retuning it. Use the same map, or it was my understanding that there was a library of OFT maps. Perhaps there is a different one that will behave better.
Have you checked your air filter? Run seafoam/fuel injector cleaner?
Old 01-19-2022, 08:45 AM   #17
02maher
02maher's Avatar
Drives: Gt86 2013
Air filter is 1.5 year old replaced it myself. I'm in Dubai they have good fuel here but no Ethanol type unfortunately.
Old 01-19-2022, 08:55 AM   #18
Ashikabi
Ashikabi's Avatar
I'm curious how your octane rating compares to American. Here 98 octane would be low grade race fuel. The highest you can get at a pump without ethanol is 94 I believe. I'm gonna guess your 98 is probably similar to our 93/94. Regardless, that's fine, so long as it's not low end fuel for commuter cars. The OFT can read info from the computer while driving right? Can you watch your AFR and related values as your RPM climbs through the affected area?
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (01-19-2022)
Old 01-19-2022, 09:35 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have an OFT, do a datalog, bet your IAM is low.
Start here.
https://www.ft86club.com/forums/show...01#post1842501
Upload to datazap.
https://datazap.me/
Post link.
Get Help.
Profit.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
02maher (01-19-2022), DarkSunrise (01-19-2022), RToyo86 (01-19-2022)
Old 01-19-2022, 10:03 AM   #20
RON vs MON ratings. We use an average of the two numbers whereas they just use the RON.
Take about 5 octane off any European (used in Dubai), Aussie or Japanese numbers .
Still stuck on what the tune is. If the stock cars were faster then why not just go back to the stock mapping and see what happens?
I think there is more to this story someplace.
Old 01-19-2022, 11:08 AM   #21
DarkSunrise
DarkSunrise's Avatar
As mentioned above if you have an OFT device, then datalog and post. That will show what's going on with your engine.
2022 BRZ Build
2013 FR-S Build
Old 01-19-2022, 11:46 AM   #22
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
How about your wheels & tires set up? What's are their sizes? What's their weight?
Sent from my SM-G781W using Tapatalk
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 01-19-2022, 12:32 PM   #23
02maher
02maher's Avatar
Drives: Gt86 2013
Start here.
Upload to datazap.
https://datazap.me/
Post link.
Get Help.
Profit.
So I just took it for a quick ride and saved 2 datalogs;
https://datazap.me/u/02maher/log-164...og=0&data=1-13
https://datazap.me/u/02maher/log-164...og=1&data=1-13
Old 01-19-2022, 12:37 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Do this.
Get car to operating temperature. Cruise at a steady RPM for a few minutes, and then post it. It is easier to see issues at steady state but from what you posted your fuel trims look jacked up. It is harder to see when you are on/off throttle a lot. Looks like you have an exhaust leak though. Looks like you are on a V4 tune as the IAM starts at .7, it does climb to .73 which is a good sign.
Old 01-19-2022, 12:44 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Also, remove "boost" and add "injection mode" to the log. You do that on the OFT in a menu with what parameters you want logged.
Yoshoobaroo (01-19-2022)
Old 01-19-2022, 12:44 PM   #26
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
IAM goes to 1 in the second log so fuel quality is probably fine. Fuel trims are definitely indicative of an exhaust leak near the O2 sensor
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (01-19-2022)
Old 01-19-2022, 02:26 PM   #27
02maher
02maher's Avatar
Drives: Gt86 2013
https://datazap.me/u/02maher/log-164...5?log=0&data=1
https://datazap.me/u/02maher/log-164...5?log=1&data=1
https://datazap.me/u/02maher/log-164...5?log=2&data=1
Last one illustrates the shaking that I'm experiencing after 2300rpm, still on certain occasion it's worse than that...
If there is an exhaust leak is it most probably before the headers?
Old 01-19-2022, 02:51 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, your LT fuel trims are maxed rich.
Simple stuff first. I would check where the header mounts to the cylinder heads, you may see black soot where it is leaking. I would also check from where the header mounts to the overpipe, and around the O2 sensors.
An indication it is leaking would look like this picture. See the soot?
clutch, evaporative, lag, misfire, system
Misfire after installing Crawford Billet Power Blocks (BPB) LaertesSon Issues | Warranty | Recalls / TSB 39 04-14-2016 08:56 AM
Lack of power, can't figure out why (Supercharged, EcuTek) EquiFox Issues | Warranty | Recalls / TSB 7 06-13-2015 09:48 PM
HKS Hi Power Spec L at 3,4&5k Rpms Donbrz Engine, Exhaust, Transmission 5 04-05-2015 11:06 PM
FRS lack of horsepower nmctacticz Scion FR-S / Toyota 86 GT86 General Forum 164 08-12-2014 11:18 AM
Poor response/power below ~2500 rpms? New car. Formula Vee Issues | Warranty | Recalls / TSB 21 02-16-2014 02:33 PM
