Old 01-12-2022, 01:18 PM   #1
chipmunk
Drives: _
Engine oil pan - gasket or RTV?
Some time over the next few weeks I plan to drop the engine oil drain pan. No reason, just because!
When you put it back on, how do you seal the pan? Gasket or RTV? If it's RTV, are there any aftermarket gaskets, like FelPro or someone else, to replace the yucky RTV? If it is gasket, can you give me the part #? I can't find it anywhere else.
chipmunk is offline   Reply With Quote
Old 01-12-2022, 01:42 PM   #2
chipmunk
Drives: _
Well... to answer my own question...
https://drivcat.com/overlays/part-de...0Gasket%20Set#
Is anyone using this? FelPro OS 30877
The Following 4 Users Say Thank You to chipmunk For This Useful Post:
bcj (01-12-2022), Bonburner (04-26-2023), Tatsu333 (01-12-2022), Ultramaroon (01-12-2022)
Old 01-12-2022, 02:11 PM   #3
Thanks for asking and answering. I wouldn't have considered it otherwise. I'll go this route when the time comes.
soundman98 (01-12-2022)
Old 01-12-2022, 02:34 PM   #4
Never used that particular gasket but back in my engine building days I would not touch anything but Fel-Pro!
You really can't go wrong with them.
Well you could go wrong I suppose but it would be on you not the gasket.
bcj (01-12-2022), soundman98 (01-12-2022)
Old 01-12-2022, 03:07 PM   #5
chipmunk
Drives: _
Had great luck with FelPro on my wife's car. I believe they are a Tier 1 supplier for OEMs.
Old 01-12-2022, 03:37 PM   #6
Yes they are. Not sure about now but back in the day they held over half the market.
Old 01-13-2022, 03:27 AM   #7
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
@chipmunk
I will buy you a 6-pack of beer (via paypal, your choice of brand/flavour) if you make a review of the FelPro oil pan gasket
Been considering using the gasket instead of RTV for the installation of the KillerBee oil-pickup tube.
Boccaccio is offline   Reply With Quote
The Following User Says Thank You to Boccaccio For This Useful Post:
chipmunk (01-13-2022)
Old 01-17-2022, 04:14 PM   #8
chipmunk
Drives: _
Can't find it anywhere! Called local shops... none! I'm probably gonna have to get large sheets and cut them myself! Or just use RTV again! :/
Old 01-17-2022, 04:32 PM   #9
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Looks like you can get it delivered from auto zone
Old 01-17-2022, 04:48 PM   #10
KillerBMotorsport
KillerBMotorsport's Avatar
Before you go down this road, ask yourself if you're going to be removing the pan anytime soon after. If the answer is yes, use a gasket. If the answer is no, use the adhesive sealant.
We use gaskets here often when doing oil product testing, because it's so much faster than cleaning adhesive gasket, but if they are on for any period of time, they almost always leak. Whenever we are through a series of tests and the car is going to events or to street duty, the liquid adhesive gasket goes back on, because when done right, it NEVER leaks.
KillerBMotorsport is offline   Reply With Quote
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post:
Rosticles (08-31-2022), soundman98 (01-17-2022), Ultramaroon (01-17-2022)
Old 01-17-2022, 06:43 PM   #11
chipmunk
Drives: _
What gaskets do you use? Where do you order them from?
Old 01-17-2022, 08:16 PM   #12
KillerBMotorsport
Have used both AutoZone and Fisher Auto gaskets.
Again, for short term use ONLY. Do not recommend for long-term use at all!
Old 01-18-2022, 05:41 PM   #13
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Just get some of that Permatex Right Stuff Grey or Black. You don't need much.
demasrv is offline   Reply With Quote
Old 04-13-2023, 12:19 PM   #14
NicFromTheNorth
Drives: Subaru BRZ 2016
I ordered this gasket from NAPA, because from the picture I thought it was made from rubber, like the inner two round gaskets. The material is actually some sort of fiber, and I decided to go with RTV instead because I wasn't convinced this gasket would seal well for years.
NicFromTheNorth is offline   Reply With Quote
Chasing an exhaust leak -Donut gasket or gasket exhaust came with? xZAMx Engine, Exhaust, Transmission 7 08-28-2019 10:47 AM
SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive el-guapin Exterior Parts (Aero, Lighting, Etc.) 5 12-27-2018 03:54 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 08:22 AM
Engine Gasket Set Ishii Motors Engine, Exhaust, Transmission 4 06-22-2012 05:33 AM
