| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
Check your owner's manual as it's designed to recommend what's best in your area. Why so? If you live in a colder climate, 0w-20 is thin enough to easily lubricate the internals in freezing temps. If you're in a hotter climate, you may not need such thin oil & a thicker one like 5w-30 may provide better protection.
Here in Canada, I've started using the FULL SYNTHETIC 0w-20 of Costco, which is a rebranded oil. It's about 50-60% cheaper at CA$39 for 2x4.73L jugs (2x 5qts) than the big brand ones but performs the same or even better. What's important is the oil has SAE-API certification. I run UEL catless + Ecutek tune.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
| The Following User Says Thank You to sygfrid For This Useful Post: | Wally86 (01-17-2022) |
#16 |
Be Kind
Drives: 2020 86
Do you mean including enough TBNs to fight formic acid if the hydrophilic properties of E85 cause it to introduce water into the engine? Oil dilution?
There's always changing your oil early and getting it analyzed.
#17 |
Drives: '13 Whiteout
I think those oils are for Diesel engines. While their chemical properties may be good I highly doubt the oil itself can compete with the high end synthetics we use. Still best just to change often.
#18 | |
Be Kind
Drives: 2020 86
| The Following 2 Users Say Thank You to Wally86 For This Useful Post: | TommyW (01-17-2022), Ultramaroon (01-18-2022) |
#19 | |
Drives: Crapcan
Basically, if you have no fuel dilution issues, there is no problem. If you have a fuel dilution issue that shows up in your UOA, address it. E85 is more acidic and can form compounds in the oil, but as long as you don't have an excess amount in your oil it is not significant.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (01-18-2022), Wally86 (01-17-2022) |
#20 | |
Be Kind
Drives: 2020 86
#21 |
Drives: Crapcan
If you check out the bobistheoilguy forums there is a lot of info on it there. Just be prepared for nerd level information on engine oil.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Wally86 (01-17-2022), Yoshoobaroo (01-17-2022) |
#22 |
Be Kind
Drives: 2020 86
That's actually where it all lead me. I'm no stranger to that site lol
#23 |
Is it compatible with alcohol based fuel? Whether it's synthetic or not really has no barring.
Trying to run E85 in some DI cars will gum up the fuel pump to the point that it will not work at all, and needs to be replaced. Not very conducive to performance. |
#24 | |
Be Kind
Drives: 2020 86
The gumming fuel pump.... that's due to the oil compatibility?
#25 |
#26 |
TRACKBREAD
What engine oil do you guys run?
What? First of all, ethanol is not acidic, it’s actually slightly basic with a ph of 7.3. Second, a lot of places in the world allow up to 15% ethanol in normal gas, so all car manufacturers make their fuel system ethanol compatible. You won’t gum up a modern fuel pump with E85.
Yes a high ethanol content can cause the oil to break down quicker if a lot of it gets in the oil from your engine being worn, but on a healthy engine with a good seal on the rings you should be absolutely fine with a quality synthetic and the manufacturer’s recommended change interval. Dexos is pure 1000% GM marketing bullshit. It’s just another excuse to deny people warranty claims for using a non-approved oil(read: no license fee to them). Running E85 is such a common performance mod these days that IF there was a big problem with it you’d see it all over the place With most modern engines being turbo DI everything from a Civic to a 911 turbo has flex fuel kits available. |
#27 | |
15% is a lot different than 85% |
#28 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Yoshoobaroo (01-17-2022) |
| Brief engine knock/cold engine/first couple accelerations@2.8-3krpm | Reyanth | Issues | Warranty | Recalls / TSB | 5 | 11-15-2020 02:32 PM |
| Need some advice on engine guys! | dsteezy86 | Northern California | 23 | 01-19-2017 07:33 AM |
| BC Coilover settings you guys guys ride on | g0lden | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-06-2014 06:56 PM |
| Do you guys have the dealership to change out your engine oil? | JS + BRZ | Southern California | 11 | 01-04-2014 12:23 AM |
