Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-04-2022, 01:49 PM   #15
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Originally Posted by PBR View Post
I ordered a 3mm larger rear sway bar, 17mm - 3 way adjustable. It's on a truck, on the way home.
Very nice. Waiting on Swift Spec R springs. Going with Bilsten B8s, Raceseng camber plates and Cusco lcas for now.
With the amount of modifications you're doing right out of the box, doesn't seem to me that the likely near-imperceptible differences between the two cars mattered a whole lot for you anyhow.
fredzy is offline   Reply With Quote
Old 01-04-2022, 01:54 PM   #16
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
But they did. Aluminum knuckles, stiffer bushings and more rear lateral stiffness with the BRZ will help those parts work better. Why i went with the Cusco. Heavier and stiffer. I don't want all that rear movement with the GR86.
PBR is offline   Reply With Quote
Old 01-04-2022, 02:06 PM   #17
*Axel
Grey Man
*Axel's Avatar
Drives: 22 MT BRZ
stiffer bushings too? Siightly heavier springs may be on the table soon too then.
*Axel is offline   Reply With Quote
The Following User Says Thank You to *Axel For This Useful Post:
PBR (01-04-2022)
Old 01-04-2022, 02:18 PM   #18
PBR
PBR's Avatar
The Following User Says Thank You to PBR For This Useful Post:
*Axel (01-04-2022)
Old 01-04-2022, 03:05 PM   #19
Tokay444
I like the grin and dimples look of the BRZ better than the inferior handling characteristics of the 86. President of Toyota Motor Corp. – Akio Toyoda -- Toyota's chief test driver must be livid.
PS - I'm only kidding around.
Something as simple as an alignment can make more of a change in handling than these two specific cars exhibit. Were their alignment settings compared?
The Ford Escape face isn't as easy nor as cheap.
Old 01-04-2022, 03:14 PM   #20
PBR
PBR's Avatar
With the same alignment, you're still going to get less movement in the rear, more linear breakaway with less lateral and vertical motion. I'll take that even just for piece of mind. Background in shifter karts. First car to really modify as much as I want so all the details are important to me even if they seem trivial to others.
*Axel (01-04-2022)
Old 01-04-2022, 04:23 PM   #21
*Axel
Grey Man
*Axel's Avatar
Drives: 22 MT BRZ
My angle is mainly 86 fanboys insulting the BRZ looks all along and now that the 86 is released, it underperforms compared to the BRZ. I especially enjoy that the smug little snob, Savagegeese, favors the 86 and his little duckling followers bought in on his bias. It's just a bit of friendly rivalry, that's all.
The BRZ front end is growing on me, like the 4th gen catfish camaro did.
PBR (01-04-2022)
Old 01-04-2022, 04:40 PM   #22
Tokay444
Still easier to press some stiffer bushings in then change the facia I’d wager.
Old 01-04-2022, 04:44 PM   #23
PBR
PBR's Avatar
I'd rather not do either. Lot of effort. Image conscious buyers are so weird lol
*Axel (01-04-2022)
Old 01-04-2022, 04:47 PM   #24
*Axel
Grey Man
*Axel's Avatar
Drives: 22 MT BRZ
Now really, it's not that bad. Everyone that sees my car up close has nothing but compliments to say about it. It's mainly social media influencers that make a big deal about it. wait till they catch onto the 86 underperformance issues.
PBR (01-04-2022)
Old 01-04-2022, 07:42 PM   #25
fredzy
Mebmer
fredzy's Avatar
Performance issues… from what I’ve read and watched on YouTube, the slight differences in character come down to subjective preferences in handling as much as the facia is a subjective thing. Take Keiichi Tauchiya for example. He drove the new twins back to back a few different times now and stated all the same things: GR is more slippery, BRZ is more planted. But if I recall correctly, when timed, he was quicker in the 86. Either way, he’s reluctant to pick a favorite. It’s probably just that both are perfectly fine and fun.. but likely also wants to avoid this sort of discussion *insert sane “lol” smiley here*
(This forum has about the worst smiley choices.)
I have no intention of hitting the track, so more playful character and better road trippability is a plus for me. When I heard that the engine tunes for the two cars are different/done by each respective OEM, that really sealed the 86 for me. If I went BRZ I’d be scrambling to get that factory tune off the car ASAP. Even without a turbo, Subaru will find some way to blow it up. I wouldn’t let them tune my lawnmower.
The Following 2 Users Say Thank You to fredzy For This Useful Post:
PBR (01-04-2022), Tokay444 (01-06-2022)
Old 01-04-2022, 07:58 PM   #26
PBR
PBR's Avatar
Totally understand this. Mine will be mostly DD and I'll be sticking with thin and tall wheels/tires. I don't want too much grip. After i saw the throttle maps that validated my choice for me. And having had it a month, the rear end steps out easily. So my reasoning is that I'd rather have the stiffer rear end and more linear throttle map to hold those drift angles more easily even if it's easier to initiate oversteer in the GR86. Also why I'm going with Swift Spec R. Softer in front. Stiffer in the rear.
Old 01-04-2022, 10:09 PM   #27
chikubi
Drives: 2022 BRZ
The BRZ is better at drifting and maintaining long drifts. The driver in this video explains that he controls the BRZ much better than the GR86
Ah, yeah, saw that earlier. You’re correct, he does find the BRZ easier to control for drifting due to its stability. The point I was getting at in my initial reply was more about how the makers have setup their vehicles for the style of driving they think their customers will enjoy the most. Even so, when you get right down to it, though, even for tail happy fun a more stable platform is still the best, as that host and some others have noted. BRZ is definitely the better of the two I think for handling in general. Can’t wait until mines arrives.
chikubi is offline   Reply With Quote
The Following User Says Thank You to chikubi For This Useful Post:
PBR (01-04-2022)
Old 01-05-2022, 12:27 AM   #28
PBR
PBR's Avatar
There's no wrong answer. Just fun arguing lol. Truth is buying a GR86 even just for that awesome logo on the steering wheel is valid. Buying the Subaru because you can't pronounce "Toyota" is valid. They're both dream cars and grateful as an enthusiast they both exist. I also doubt there will be many new cars I'll be interested in the years to come. So when it's time for my next car, might be a GR86 to switch things up lol. Cheers man.
ForeverCar (01-05-2022)
GR86 vs. GT86 track comparison nikitopo GR86 General Topics (2nd Gen 2022+ Toyota 86) 5 12-30-2021 07:48 PM
GR86/BRZ Track Comparison (Japanese) Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 95 12-24-2021 07:36 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-18-2021 04:38 PM
pic request : japanese oem details on brz/gt86 Zoik Cosmetic Modification (Interior/Exterior/Lighting) 1 05-23-2019 07:05 PM
Japanese Kiramek Car Alarm BRZ/Scion FR-S/GT86 Trap63 Electronics | Audio | NAV | Infotainment 1 02-28-2014 05:21 PM
