Old 12-31-2021, 09:06 AM   #1
Youx
Drives: Toyota GT86 2012
Scary noise on cold start
Hello,
I’m slightly worried, as I just got a very strange noise.
I started my 86 (1 week since last use) inside my garage (temperatures are pretty high for winter, 15°C/59°F).
Motor revs to 1500, as usual, then I get a loud sound « ta-ta-ta-ta-ta-ta-ta ». Kind of like firecrackers, or when your exhaust has holes, but I’d say higher pitched. A bit metallic, but maybe that’s my mind. And definitely loud enough to be heard over the motor, with doors and windows closed.
Anyway, it lasted maybe a 5 seconds, while I was WTF-ing, then it disappeared, RPM revved down to 1000, and I did not hear it anymore as I went shopping.
How worried should I be?
Edit: car is 2012, stock, and I pressed the clutch pedal during the sound and it did not seem to affect it.
Youx is offline   Reply With Quote
Old 12-31-2021, 10:27 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What is the mileage (kilometerage?) on your engine? A video with sound would be helpful.
Old 12-31-2021, 11:05 AM   #3
Youx
~82000km. The recall was done last December.
I’ll try to start it every few days, with a phone ready to record, in case it repeats.
The Following User Says Thank You to Youx For This Useful Post:
Ultramaroon (12-31-2021)
Old 12-31-2021, 11:25 AM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What oil are you using
TommyW is offline   Reply With Quote
Old 12-31-2021, 11:25 AM   #5
blsfrs
blsfrs's Avatar
First guess would be a rod knocking until the oil pressure built up but your engine mileage is rather low for that.
Old 12-31-2021, 12:25 PM   #6
Youx
The one that Toyota puts in at maintenance, so 0w20 iirc?
Old 12-31-2021, 03:05 PM   #7
TommyW
TommyW's Avatar
Hmmm yeah plenty thin. You had the recall done and that's a red flag. If they let silicon get in the engine it may be clogging things up and compromising the oil flow. Keep an eye on it. Not much you can do if that's the case. Yes try starting it often to keep a film of oil on the bearings
Old 12-31-2021, 03:23 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If it keeps doing it, try priming the oil pressure when starting it cold. You do this by holding the gas pedal down when starting the car. It will crank, but not start until you take your foot off the gas. Let it crank ~3-5 seconds to let the oil pressure build up, then let it start.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
humfrz (12-31-2021), RToyo86 (01-17-2022), wbradley (12-31-2021)
Old 12-31-2021, 04:14 PM   #9
Will check back for the recorded sound.
humfrz (12-31-2021)
Old 12-31-2021, 06:55 PM   #10
What part of « ta-ta-ta-ta-ta-ta-ta »,, don't you understand?
JD001 (01-16-2022), soundman98 (12-31-2021)
Old 12-31-2021, 07:53 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Maybe a piece of the cat honeycomb broke loose
The Following User Says Thank You to wbradley For This Useful Post:
Old 12-31-2021, 07:58 PM   #12
At this point, all I have is the mental picture of a man saying it with a French accent.
humfrz (12-31-2021), soundman98 (12-31-2021)
Old 12-31-2021, 08:32 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Decep (01-03-2022), humfrz (01-01-2022), soundman98 (12-31-2021)
Old 01-06-2022, 02:54 PM   #14
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
as a professional wrench, there are at least 5 normal issues that make this kind of noise. Its definitely a relevant thing to want to listen to it.
For example, is it a lifter not pumping up quickly? Or an exhaust manifold leak? Or a heat shield? Or an item stuck in the belt that flung itself out after a bit? All completely different diagnosis and prognosis. All to Tatatatatatata
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following 2 Users Say Thank You to JohnH For This Useful Post:
humfrz (01-06-2022), Ultramaroon (01-06-2022)
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 04:21 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
Perrin CBE crackling noise during cold start tracerit Engine, Exhaust, Transmission 8 02-26-2015 04:43 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 08:15 PM
Cold Start Clunk Noise Luckrider Issues | Warranty | Recalls / TSB 6 11-28-2013 06:02 PM
