Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-25-2021, 07:33 PM   #1
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Tall People Solutions?
I am interested in buying a 2022 BRZ base to replace both my 13 FRS and 09 335d but the seating position is terrible compared to my 13 FRS and previous 14 BRZ. I like to sit quite upright and close-ish to the wheel and find my head has zero room for a helmet (not even enough head room without a helmet) and my right knee hits the column plastic with it all the way up. I figure minimum an inch lower is what I need to consider the car, but I also am not sure what’s going to be involved wiring/warning light defeat wise to change seats and brackets. Also do we know yet eta for aftermarket seat/rail options or whether 1st Gen aftermarket parts are likely to fit?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 12-25-2021, 08:41 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Anything aftermarket will not have a side airbag, which IMO is a non-starter for a daily driven car.
On top of that, many argue that fixed-back bucket seats are unsafe at the track without a roll bar / half cage.
Previously I looked into fabricating a custom bracket for the 1st gen to mount the stock seat an inch lower, but couldn't figure out an easy way to do it.
The good news is the 2022 seat is attached to the seat rails differently than '13–'20. This time they went with four horizontal bolts, so perhaps two L-shaped brackets is all that's needed to mount the stock seat in a fixed lower position.
The challenge might be to figure out how to bolt the brackets to the floor when the seat is in place. Might require some serious car yoga!
Another possibility is to do foamoctemy to the lower seat cushion.
The Following User Says Thank You to timurrrr For This Useful Post:
dsc_pat (12-25-2021)
Old 12-26-2021, 12:12 AM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I would suggest reverting to your teenage form to reduce your height. But I'm not qualified, nor tall enough, to give a good solution.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
alex87f (01-01-2022)
Old 12-26-2021, 12:42 AM   #4
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
I have the same problem. I also prefer to be sitting more upright, and the BRZ does not allow for this, nevermind with a helmet on. I will also be looking at many different solutions, custom brackets or a different seat, maybe remove the headliner? Every millimeter counts at this point.
Midnightsky is offline   Reply With Quote
Old 12-26-2021, 06:48 AM   #5
Riki
Drives: renault clio rs
Recaro sportster CS has airbags.
Riki is offline   Reply With Quote
Old 12-26-2021, 08:32 AM   #6
BRZ549
Drives: '90 TA, '03 WRX, '97 Del Sol
How tall are you guys?
BRZ549 is offline   Reply With Quote
Old 12-26-2021, 02:25 PM   #7
Jdmjunkie
Drives: Scion FR-S 10 Series
I don't think we can get those in North America. I would love a pair though.
Jdmjunkie is offline   Reply With Quote
Old 12-26-2021, 03:24 PM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
First gen stuff bolts in, supposedly.
That said, I definitely felt like the seat sits higher too in the second gen, but I still have decent headroom even with a helmet at 6'4" and I'd love to keep stock seat and lower it, like the Aurora Auto Designs lowering rails for the ND Miata
The Following User Says Thank You to DocWalt For This Useful Post:
Ultramaroon (12-26-2021)
Old 12-26-2021, 05:02 PM   #9
There are a shit ton of us tall people in these things because we're all would-be mr2/s2k/miata owners had we fit in any of those.
That's my story and I'm sticking with it.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
Capt Spaulding (03-28-2022), FeRS (03-27-2023), Jucostud (01-06-2022), Midnightsky (12-26-2021), rawpoly (12-26-2021), ROFL it's Waffle (07-12-2022), Spuds (12-26-2021), surfwaxsmitty (10-03-2022), timurrrr (12-26-2021)
Old 12-26-2021, 05:19 PM   #10
Midnightsky
Truth!!!!! K-swapped MR2
The Following User Says Thank You to Midnightsky For This Useful Post:
Old 12-26-2021, 05:25 PM   #11
NikolaiCherepanov
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
Im 6'1 and I sight directly upright as well I fit just fine however I would not be able to wear a helmet unless I move the seat back. Do you have more leg length or more torso length? I actually sit further up in the BRZ than I do my Z3 as the pedals in my BMW are so much closer to my feet I can push the seat back a bit. Also do you have the pitch of the seat cranked down? Ive found you can gain a little more clearance by pitching the seat a bit
NikolaiCherepanov is offline   Reply With Quote
The Following User Says Thank You to NikolaiCherepanov For This Useful Post:
Spuds (12-26-2021)
Old 12-26-2021, 05:33 PM   #12
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So, just confirming, seat bottom as low/tilted back as it can go, steering wheel pulled as far out as possible? I've found you can get a few more millimeters longitudinally on the gen1 steering wheel if it's tilted a few degrees down from the topmost setting. Might want to try a couple clicks back on the seat and tilt the wheel down a bit. Aftermarket steering wheel might help too.
The Following User Says Thank You to Spuds For This Useful Post:
Old 12-26-2021, 06:13 PM   #13
Midnightsky
When I did my test fit at the dealership, I actually wished that the steering wheel would have come out further.
Old 12-26-2021, 06:23 PM   #14
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent
In 1989, I sat in a Miata and my head just touched the cross bar on the convertible top. I knew instinctively that several miles of my head bouncing off that bar would be a big pile of regret. Over the years I would try out the next iteration of the MX5 and no dice. I am only 6' tall. The BRZ fits like a glove, problem solved.
Flarpswitch is offline   Reply With Quote
I finally found seats for big and tall people! arkanist Cosmetic Modification (Interior/Exterior/Lighting) 28 11-26-2019 06:31 PM
How tall are you djmm Scion FR-S / Toyota 86 GT86 General Forum 122 12-26-2013 05:05 PM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 07:19 PM
Seat fit for tall people? clubraf Scion FR-S / Toyota 86 GT86 General Forum 14 06-29-2012 11:51 AM
How tall are you? ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 111 11-14-2011 04:32 AM
