Old 12-20-2021, 02:41 PM   #1
e_lunatic
Drives: 2015 Scion FR-S
Clutch fork upgrade needed
Replacing the clutch in my 2015 FRS and was going to upgrade the clutch fork but reading up on them the description is talking about the upgrade as being needed for use with stronger pressure plates. If i'm not beating on the car (daily driver only) and going with an OEM clutch and parts should I just leave it alone?
e_lunatic is offline   Reply With Quote
The Following User Says Thank You to e_lunatic For This Useful Post:
humfrz (12-24-2021)
Old 12-21-2021, 01:40 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Depending on your mileage, it might be worth to just get a new OEM one and put it in
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
e_lunatic (12-24-2021), Opie (11-12-2023)
Old 12-21-2021, 10:11 AM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Verus
TommyW is offline   Reply With Quote
Old 12-21-2021, 01:02 PM   #4
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
FWIW - my '15 is mostly OEM. When I replace the clutch I'll use a Verus fork and pivot.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-23-2021, 03:53 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
replace it with Verus fork.
Old 12-24-2021, 01:02 PM   #6
Sooooo, how did you manage to wear out the OEM clutch?
Old 12-24-2021, 02:54 PM   #7
e_lunatic
I should have said it's my daily now. When I bought the car I used to clutch kick it and beat it up a little as it was my weekend play car. It's been my daily for 2 years now and it's babied now but i took a few years off its life early on.
I am making an assumption its the clutch based on the noise it makes when the clutch is in it makes a metal on metal sound that has gotten progressively worse the past 3 weeks.
humfrz (12-24-2021)
Old 12-27-2021, 11:37 AM   #8
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Versus. Done.
vfrqqq is offline   Reply With Quote
The Following User Says Thank You to vfrqqq For This Useful Post:
x808drifter (12-28-2021)
Old 12-27-2021, 09:22 PM   #9
JONCOFF
Drives: 13 FRS, 08 Yaris, 97 318iS
You are describing the sounds my throw-out bearing made as it puked. How many miles do you have on the car? Verus offers it's fork, with a throw-out bearing at a good price. And get the pivot for a little more. If you are going to keep the car, do the clutch and the Verus fork with a new throw-out, and as long as you don't beat on it, the combination will last longer than you will keep the car. A major part of the money involved is, if you don't do you own work, pulling the transmission.
JONCOFF is offline   Reply With Quote
The Following 2 Users Say Thank You to JONCOFF For This Useful Post:
e_lunatic (12-30-2021), humfrz (12-28-2021)
Old 12-30-2021, 01:37 PM   #10
e_lunatic
Yep the throw out bearing was on its way out. Everything swapped out fine. car has 64k on it. Unfortunately because of the time i had scheduled to have the work done the Versus fork didn't come in time so it didn't get done. This car will be my daily for another year and then it's going back to be a weekend/play car. If the stock fork starts to give way I will have the time to pull the transmission and replace the fork at that time.
Old 12-31-2021, 01:09 AM   #11
FrickingReallySlow
Drives: 2015 FR-S
Didn't see this in time, but the OEM fork actually went through 2 updates. With the latest one also being used for Gen2 which has to handle more torque and herspers so ppl might want to give the new updated version a try if they're not 300bhp+. Its 30531AA220 for both gens and only $26 instead of $175 for verus
FrickingReallySlow is offline   Reply With Quote
The Following 2 Users Say Thank You to FrickingReallySlow For This Useful Post:
e_lunatic (12-31-2021), TommyW (12-31-2021)
Old 01-02-2022, 11:04 AM   #12
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Anybody have a side by side comparison of 1st and 2nd gen forks?
Old 01-02-2022, 11:58 AM   #13
WNDSRFR
Drives: FR-S,GTI
I have a 1st gen fork on my 200,000 mile "13 FR-S. On my third TOB but the fork is original. Works fine, lasts a long time.
I guess I could spend a bunch of money on an aftermarket part, but why?
Old 01-03-2022, 04:48 PM   #14
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I'll work on ordering one to compare to the factory units we have here.
You are one of the lucky ones. We've seen people with cars that are barely out of warranty broken in various locations. No rhyme or reason for the failures.
VerusEric is offline   Reply With Quote
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
blsfrs (01-03-2022), Jdmjunkie (01-03-2022), Teseo (01-04-2022), x808drifter (01-03-2022)
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 10:31 PM
[SOLD!] FS: NEW Diftech Heavy Duty Clutch Fork + Versus Clutch Fork Pivot reeves Transmission and Driveline 2 08-25-2018 12:18 AM
Is a clutch fork considered part of the clutch? BuzzR Engine, Exhaust, Transmission 10 06-28-2018 07:58 PM
Clutch Fork Failure - i.e. New Clutch and Tranny BuzzR Engine, Exhaust, Transmission 11 06-22-2018 02:53 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
