Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2017 Toyota 86
#16 |
#17 |
Drives: Crapcan
Aftermarket wheels are an option, not a requirement. You have all the time you need. I'd recommend looking into different sizes and offsets. If you go too wide or don't run the right offset you may run into strut clearance issues.
#18 | |
Oh yea, the car is completely Stock, aside from the cut out diffuser but I don’t think that really matters. I mean, what if I get the +22 rays, and save up money to get the chamber I need then lower the car Sent from my iPhone using Tapatalk |
#19 | |
Yes Ik, but the tires aren’t. I kind of need them immediately. My rear tires are bald and my dad keeps pushing me on getting new tires. So I thought get them all together while I have the chance Sent from my iPhone using Tapatalk |
#20 | |
Drives: '23 BRZ
Even at +35 you'll need some negative camber to keep the fronts from sticking out. +22 is just going to be a disaster without significant camber and some bodywork. Even with +35, IMO you'll want to lower it a bit and get significantly more front camber than stock to tuck the front tires in. |
#21 |
LMGTFY
Drives: 13 FRS, 91 Miata
After reading all this.
Just get new tires for your OEM wheels. You are WAY in over your head right now. |
#22 | |
Yea I am , but like, when I do have the knowledge and know what I’m doing, I don’t want to waste even more money on new tires to fit the new wheels Sent from my iPhone using Tapatalk |
#23 | |
Drives: '16 BRZ Limited
Think your best option might just be get new tires for stock now and then whenever it's time to replace the newly purchased tires then you can buy a wheel & tire package to allow yourself time to research and not rush into a purchase. |
#24 | |
Drives: 2016 HyperBlue
Here is some good fit advice. https://support.apexraceparts.com/hc...-Fitment-Guide |
#25 | |
This is perfect, thank you very much Sent from my iPhone using Tapatalk |
The Following User Says Thank You to IamKevin2 For This Useful Post: | nathand (12-16-2021) |
#26 |
Drives: 2020 Subaru BRZ (Edelbrock SC)
I went for 17x9 +38 for my 57CR's. Like others have said, fitment is flush with the fender when running some camber (no more than 2 deg). 245/40/17 PS4S tires.
I honestly can't complain. It super grippy and looks/feels fantastic. I went with 17's instead of 18's because I did not want to mess with my speedometer. Mine is so far only a daily/weekend car until it looses its virginity to the track. |
#27 | |
I see, after some time tho, I probably just gonna go with some KNPs instead of the rays, but if I do go with rays , I’ll come back to this, so I appreciate it Sent from my iPhone using Tapatalk |
#28 | |
Those look super fresh too, I would definitely get those. If you go with a similar setup to mine you won't be disappointed! |
WTB: RAYS 57CR Gold | Clark20 | Want-To-Buy Requests | 0 | 02-14-2020 07:25 PM |
FS:[IL/WI] RAYS Engineering 57CR 18x9.5 EDP | NEW IN BOX | BanditKeith | Wheels and Tires | 2 | 01-24-2020 07:24 PM |
Rays Gram Light 57CR - ALL NEW COLORS | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 04-05-2018 05:41 PM |
RAYS Gram Light 57CR | DesertLava | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-26-2017 11:55 AM |
New Rays Gram Lights 57CR - ALL NEW COLORS | FT-86 SpeedFactory | Wheels and Tires | 3 | 08-07-2017 09:45 AM |
