Old 11-28-2021, 06:32 AM   #15
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Originally Posted by Poogchomp View Post
+38 offset pushes the wheel out more by 7mm over a +45. Spacers would just push it out even further.
makes sense idek what I was thinking haha so 5mm should be close to perfect right?
blakkoutdarko is offline   Reply With Quote
Old 11-28-2021, 11:23 AM   #16
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
It'll be off by about 1/5 of an inch compared to the car you're using as an example. If you consider that close, then yes it'll be close to perfect.
Poogchomp is offline   Reply With Quote
The Following User Says Thank You to Poogchomp For This Useful Post:
blakkoutdarko (12-13-2021)
Largest tire for stock suspension? Razorlor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-23-2018 06:43 PM
Need advice on suspension and wheels setup djdrugga24 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-10-2018 06:07 PM
BRZ Winter Tire/Wheels Setup? cbamf8 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 12-20-2017 08:45 PM
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 04:25 PM
Best setup with st coil overs on stock wheels?? Vincenttam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-01-2015 03:29 PM
