Drives: 17 Asphalt 86
Adjusting window regulator
Does anyone have a diagram of the window regulator and how to adjust it correctly?
The window regulator was replaced just prior to the warranty expiring, but is in need of adjustment. The tint has been scratched on the inside of the glass. ![]() I'm going to fiddle with it soon while replacing the door speakers. |
#2 |
ProCrastinationConsultant
i believe you need to adjust the grip of the felt pads inside the door, and not the regulator to correct that.
| The Following User Says Thank You to soundman98 For This Useful Post: | RToyo86 (11-07-2021) |
| Switched out window regulator. Now my window decided that this will be its max height | kev0 | Issues | Warranty | Recalls / TSB | 13 | 07-21-2021 10:10 PM |
| DIY: Window Motor & Regulator Replacement | thekevinvo | DIY (Do-It-Yourself) Guides | 0 | 09-03-2020 03:46 PM |
| Fuel Regulator | tofurun | Forced Induction | 9 | 01-09-2017 10:11 PM |
| Window Regulator Bolts/Washers - TSB and new parts? | PollosHermanos | Issues | Warranty | Recalls / TSB | 3 | 03-08-2014 02:17 PM |
| Window Regulator Mounting Bolts - Noise Issue & Part Revision? | PollosHermanos | Issues | Warranty | Recalls / TSB | 1 | 03-06-2014 11:39 AM |
