Old 10-29-2021, 03:55 AM   #1
prannoy
Drives: Toyota 86, 2013
Unhappy Clutch slipping for one second
Hi guys,
So I’m kinda new to the group.. and I had a small question.
I own a Toyota 86, 2013 model. 165k km on the odo. 2 weeks back I started hearing a very slight “shhhh” sound when I engage my clutch that only I can hear when the car is silent.. Did a couple of research and I thought it could be the throw out bearing(I could be wrong). Anyways fast forward two weeks, last night, I went for a drive, kinda pushed my car from second to third gear, and later I was driving down the highway, and I noticed on my 5th gear when I was pressing on the gas pedal, around 3.5 rpm my clutch slipped for one second till 4 rpm and came back to normal. Same thing happened on 6th gear as well. But the car runs absolutely fine on all other gears. No clutch burning smell, no gear cranking sound, nothing.
Do you guys have any idea what could be the issue? A million thanks in advance!
prannoy is offline   Reply With Quote
The Following User Says Thank You to prannoy For This Useful Post:
humfrz (10-29-2021)
Old 10-29-2021, 06:59 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The clutch is worn out.
Replace it and the TOB before you get stranded somewhere.
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (10-29-2021)
Old 10-29-2021, 02:41 PM   #3
Originally Posted by prannoy View Post
Hi guys,
With that many miles (km) on a 2013, if the TOB hasn't been replaced, it would be a good preventative maintenance thing to do. While you are in there, might as well replace the clutch and pressure plate too.
Ultramaroon (10-29-2021), x808drifter (10-29-2021)
Old 10-29-2021, 03:37 PM   #4
+1
clutch, clutch slipping, transmission
grinding noise while turning/slipping clutch JackRabbit Issues | Warranty | Recalls / TSB 5 09-07-2019 03:06 PM
Brand new clutch slipping under boost. Olson1288 Engine, Exhaust, Transmission 16 08-01-2019 01:53 PM
Driving under 3mph vs. slipping the clutch cat94 Engine, Exhaust, Transmission 31 02-14-2017 04:28 AM
new clutch slipping already? nickmerronesucks Engine, Exhaust, Transmission 12 10-07-2015 03:33 PM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 10:56 AM
