Drives: Toyota 86, 2013
Hi guys,
So I’m kinda new to the group.. and I had a small question. I own a Toyota 86, 2013 model. 165k km on the odo. 2 weeks back I started hearing a very slight “shhhh” sound when I engage my clutch that only I can hear when the car is silent.. Did a couple of research and I thought it could be the throw out bearing(I could be wrong). Anyways fast forward two weeks, last night, I went for a drive, kinda pushed my car from second to third gear, and later I was driving down the highway, and I noticed on my 5th gear when I was pressing on the gas pedal, around 3.5 rpm my clutch slipped for one second till 4 rpm and came back to normal. Same thing happened on 6th gear as well. But the car runs absolutely fine on all other gears. No clutch burning smell, no gear cranking sound, nothing. Do you guys have any idea what could be the issue? A million thanks in advance! |
| The Following User Says Thank You to prannoy For This Useful Post: | humfrz (10-29-2021) |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
The clutch is worn out.
Replace it and the TOB before you get stranded somewhere. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Ultramaroon (10-29-2021) |
#3 | |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (10-29-2021), x808drifter (10-29-2021) |
#4 |
+1
| Tags |
| clutch, clutch slipping, transmission |
| grinding noise while turning/slipping clutch | JackRabbit | Issues | Warranty | Recalls / TSB | 5 | 09-07-2019 03:06 PM |
| Brand new clutch slipping under boost. | Olson1288 | Engine, Exhaust, Transmission | 16 | 08-01-2019 01:53 PM |
| Driving under 3mph vs. slipping the clutch | cat94 | Engine, Exhaust, Transmission | 31 | 02-14-2017 04:28 AM |
| new clutch slipping already? | nickmerronesucks | Engine, Exhaust, Transmission | 12 | 10-07-2015 03:33 PM |
| FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? | rinnamon | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 08-08-2014 10:56 AM |
