Old 10-05-2021, 10:06 PM   #15
FrickingReallySlow
Drives: 2015 FR-S
cool, keep us posted on your cleaned injectors results!
FrickingReallySlow is offline   Reply With Quote
Old 10-27-2021, 02:01 PM   #16
Butterballz
Drives: Black FRS
Bad news on the update. Cleaning the direct and port injectors did not fix the issue. Misfire on cylinder 2 on cold start but when start up sequence finishes, does not misfire. I haven't driven the car yet since it's at the shop but they said it drives fine once the start up sequence ends. Redline pulls in 3rd gear no misfire so they think it's the tune or maybe a sensor is bad.
Swapped coil packs around, new spark plug in cylinder 2, fuel pressure good, compression and leak down good, no carbon buildup on valves.
Kinda wished I didn't fill with e85 to see if it cleared things before sending to shop. Need to drain or use up the fuel before switching to stock tune to see if its the tune.
Butterballz is offline   Reply With Quote
Old 10-27-2021, 03:16 PM   #17
Joon525
Joon525's Avatar
Drives: 2016 BRZ
When you say you swapped them, are you moving the IP Quad Sparks around or do you mean you are putting the stock ones back in?
Joon525 is offline   Reply With Quote
Old 10-27-2021, 04:10 PM   #18
Butterballz
Drives: Black FRS
Swapped the cylinder 4 and cylinder 2 coilpacks. Misfire still localized to cylinder 2.
Old 11-04-2021, 09:59 PM   #19
Butterballz
Drives: Black FRS
If anyone wants to look at my logs it would be greatly appreciated. Had a few look at it on Facebook, but nothing on the logs pointed out to the problem. Just a very strange misfire. Kind of coming down to a electrical issue/ignition issue. Maybe bad sensor or a break in wire somewhere.
https://datazap.me/u/butterballz/mis...?log=0&data=31
https://datazap.me/u/butterballz/mis...?log=1&data=31
One log is during cold startup, this is where I get lots of misfires and hard misfire code in cylinder 2.
Second log is driving it around after warming up, different load/rpm range, cruising to redline. No misfire except under certain repeatable scenarios. Basically giving it about 50% load around 3k rpm can make cylinder 4 misfire enough to soft code.
Old 11-06-2021, 08:26 PM   #20
Something is wrong with #2 direct injector. As soon as it switches to 100% port injection, #2 misfire count goes to zero.
That is, as long as the correct cylinder is reported to be misfiring. ...but it's one of your direct injectors.
edit: ...or the signal/power to that injector.
Old 11-08-2021, 02:17 PM   #21
Butterballz
Drives: Black FRS
I think it was the coilpacks. I swapped back to OEM and did not get cold start misfires, but I didn't get a chance to log. Also drove around and tried to get it to misfire by giving it 50% load at 3k rpm, which usually starts to misfire, but did not get anything. It usually misfires cylinder #4 this way.
Didn't get a chance to log during cold start after swap, but so far signs are good.
Old 11-08-2021, 04:29 PM   #22
We'll be here when it craps out again.
Old 11-09-2021, 01:13 PM   #23
Butterballz
Drives: Black FRS
https://datazap.me/u/butterballz/log...31-48-49-50-51
So far so good. No misfires on cold start.
The Following User Says Thank You to Butterballz For This Useful Post:
Ultramaroon (11-09-2021)
Old 11-09-2021, 01:25 PM   #24
Looking good! I'm baffled but who cares? Send it.
Old 11-19-2021, 12:55 PM   #25
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I dunno, maybe it's too many years dealing with 60s and 70's vintage motorcycles with weak ignition systems but misfires under load just scream SPARK in my ears. I had a couple of Honda single cam cb750s and once the plugs got a few miles on them they would develop a case of the blind staggers at anything over half throttle. I eventually reworked the ignition system from points to electronic triggers and upgraded the coils and never had another problem.
Edit: and I won't even mention Brit bikes. My Nortons were testimonials to Joe Lucas' title of "Prince of Darkness."
I had a picture that was supposedly of him on my garage wall. The caption said "Be Home Before Dark." Oops I guess did mention them. The most damaging lies we tell are those we tell ourselves.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 09-09-2022, 05:45 PM   #26
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Looks like this one is resolved and long fixed, but I found a lot of interesting info in this thread on the same topic.
https://www.ft86club.com/forums/show...cts+quad+spark
After reading through it all, especially with 13-14 models, it looks like the pins don't make robust contact and are party to the misfires.
I have a mild misfire issue comparatively and plan on the pin tweak this weekend. I've only had two misfires recently, and I get them only when pulling to 7k, and intermittently as I haven't been able to repeat at will. So I'm not swapping parts yet to see if signal follows, just seeing if I can make it go away as one user in the other thread had good luck with.
jeepmor is offline   Reply With Quote
Old 09-12-2022, 01:03 PM   #27
jeepmor
Pin tweak didn't help me, but it is simple enough if you have the proper pliers. I left mine turned about to the point it's just noticeable. Regular needle nose are too large to fit in the connector housing. Oddly, got a CEL at the same 7k conditions, but it didn't record the code as I showed none when I checked with my reader. I even checked twice.
Logs - Misfire Cylinder #1 Butterballz Issues | Warranty | Recalls / TSB 8 06-06-2021 12:47 PM
P0300 Random cylinder misfire Grady Issues | Warranty | Recalls / TSB 6 12-02-2020 12:52 PM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 11:38 PM
P0463, u0122, and P0301 Cylinder 1 misfire Shark_Bait88 Issues | Warranty | Recalls / TSB 0 08-12-2019 07:34 PM
