Drives: 2017 Subaru BRZ
How to depin headunit harness pins?
I installed a aftermarket headunit and have been trying to move a pin from the 10pin connector to the 28pin connector. See here: https://imgur.com/nfHKi7j
My (simple) issue is trying to remove the pin from the connectors. Does anyone have a guide/know how to depin these connectors? I have a few pin extractors for depinning but just putting it in the hole above the connectors does not do the trick. These are the connectors I’m trying to depin: https://imgur.com/a/EW1yoKg Thanks. Last edited by shlr; 10-17-2021 at 06:48 PM. |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
There's a crap-ton of various and sundry de-pinning tools and virtually none of them work with a different model connector.
https://www.amazon.com/Extractor-Dep.../dp/B0922GF9W8https://www.amazon.com/Extractor-Dep.../dp/B0922GF9W8
"I gotta rock." -- Charley Brown |
#3 | |
#4 |
ProCrastinationConsultant
well, the simpler answer is that you can't move anything from the 10-pin to the 28 pin because the pin styles are different sizes.
i also would never re-pin the vehicle-side harnesses. GET ADAPTER HARNESSES AND HACK THEM UP. #triggered re-pinning oem harnesses works great until you need to troubleshoot it after forgetting what you did all those years ago--how do you think i know this one? ![]() and i know #fuck-the-next-guy™, but re-pinning oem harnesses almost entirely dooms the vehicle to an early death if you sell from being bored of it in 2 years, and they try to re-use those same harnesses in a different way, all the while, it starts popping fuses. an electrician once taught me: don't ever leave a mess for the next guy to fix, because half the time, it means you'll be that next guy." add-on adapter harnesses are less than $50. just get the harness.
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
| fs: DIY 6pins to 8 pins harness | fibber1200 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-30-2020 01:06 PM |
| Adding radio harness pins | lbroskee | Electronics | Audio | NAV | Infotainment | 0 | 04-08-2016 04:08 PM |
| BRZ Radio Breakout Harness and/or Pins and Sockets | nquillen | Electronics | Audio | NAV | Infotainment | 4 | 06-22-2014 11:40 PM |
| Foglight Harness Pins for sale | FRSHunter | Hawaii | 3 | 08-22-2013 01:29 AM |
