View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-28-2012, 11:01 AM   #533
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Pscylo View Post
But the Title of that report is:
A Technical Assessment of
E10 and E20 Petrol Ethanol Blends Applied to
Non-Automotive Engines.
Last I checked, this is indeed an automotive engine....not saying it doesn't have some relevant points...just sayin
However it does mention automotive engines since they also built them and an engine is an engine and capable of powering many different things.
Someone mentioned 2T as not being suitable for a car because it's used in engines that power other machinery but the fact that the 86 is a car is largely irrelevant while we are discussing problems caused by ethanol in an engine.
If anyone can find a better article I would be very appreciative. That was the only one I found worth mentioning.
Goodnight.
sierra is offline   Reply With Quote
Old 07-28-2012, 11:24 AM   #534
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Which is why I did include "not saying it doesn't have some relevant points," in that.
:happy0180:
Pscylo is offline   Reply With Quote
Old 07-28-2012, 11:34 AM   #535
Marrk
Drives: Honda Fit
Originally Posted by sierra View Post
You make broad statements that make no sense when compared to the large amount of evidence posted on this forum.
Your conclusion is in the same category.
Why have many pumps already been replaced in attempts to shut the chirping up if it's normal?
Why does a tiny amount of fuel lubricant stop the noise instantly?
Here's a bit more taken from a report carried out by Orbital Eng. in Perth WA
http://www.environment.gov.au/atmosp...assessment.pdf
Potential causes of failure specific to E20 fuel, in order of significance, were found
to be the following:
• Material degradation
• Gumming
• Lubrication deficiency
• Altered combustion
• Fuel properties
The study in the link is for non-automotive engines, i.e., a 15-hp marine engine and a line trimmer engine. Does it say in the study if these were 2-stroke or 4-stroke engines?
Marrk is offline   Reply With Quote
Old 07-28-2012, 11:31 PM   #536
sierra
:happy0180:
I appreciated that bit.
Please have a read and let us know.
The point being raised was that E20 was found to have lubrication deficiency. Who cares what engines were used and what they were fitted to, it was the fuel being tested to see how it compared with ethanol free?
Old 07-28-2012, 11:35 PM   #537
Marrk
Drives: Honda Fit
Wow. If you're going with that, then I'll wish you luck and say good-bye.
Good-Bye.
The Following User Says Thank You to Marrk For This Useful Post:
sierra (07-29-2012)
Old 07-29-2012, 12:18 AM   #538
sierra
Good-Bye.
If you or anyone else can come up with something better please do, I for one would be interested to read it.
I've also done a bit of research on direct injection HPFP noise and can only find the operating solenoids tapping as being a problem. No mention of any other noise such as chirping. That suggests again, that the fault is with this pump and it needs to be modified.
I don't mean to come across as having the shits but it does read that way when I look back. So sorry if I've seemed a bit short and I genuinely welcome any constructive comments.
Old 07-30-2012, 08:44 AM   #539
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
FWIW i got a P1235 code this wknd.
edit: i guess i could give more detail. P1235 is fuel pump controller out of range.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
The Following User Says Thank You to BadCompany235 For This Useful Post:
Marrk (07-30-2012)
Old 07-30-2012, 09:40 AM   #540
Marrk
Drives: Honda Fit
Bad, is that code for the HPFP? Or for the fuel pump in the fuel tank?
Old 07-30-2012, 10:47 AM   #541
BadCompany235
#TrackAddicts
i do not know. haven't gone back to a dealership yet to ask.
Old 07-30-2012, 11:37 AM   #542
Fenrir
Drives: Mazdaspeed 3
http://engine-codes.com/p1235.html
Sounds like an electrical issue.
Fenrir is offline   Reply With Quote
The Following User Says Thank You to Fenrir For This Useful Post:
Marrk (07-30-2012)
Old 07-30-2012, 02:11 PM   #543
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
ok i know we are all going a little too crazy with the chirp and honestly it doesnt really bother me...my tc did the same and so did my integra, but today i needed to get gas and decided to go sunoco gas station instead of shell to see if there was a difference.(sunoco was also 0.15 cheaper than shell lol) Took my car for a little 50 mile road trip and notice my car felt a bit smoother than usual(also cud be because i just hit the 600mile mark and the car is getting closer to break in mark).. ne ways i had chirps only when my car wud sit at idle and today after my road trip the chirps went away. sunoco has 10% ethanol...i dunno how ppl feel about sunoco but so far its looking good..just wanted to give me 2cents
brichard0625 is offline   Reply With Quote
Old 07-30-2012, 03:01 PM   #544
Jayde
Jayde's Avatar
I don't recall my Integra chirping at an idle.
I've tried Sunoco, Shell, and Mobil with the same results. It's possible that your tank still had a little gas left in it from Japan. Give it a few more miles and make sure it gets nice and warmed up (15+ miles or so) and then see if it still happens.
Jayde is offline   Reply With Quote
Old 07-30-2012, 03:08 PM   #545
brichard0625
i had an 01 integra ls and that thing ticked like crazy lasted me 120miles before i sold her(i still miss her). doubt it has anygas left...this is my 2nd fill up...first fill up was with shell 93. it is a bit cooler today but i drove for 50 miles and when i parked the chirp was gone. later on ill rev her up a little and see if it still happens.
Old 07-30-2012, 03:22 PM   #546
Jayde
Jayde's Avatar
I had an 97 myself, and I don't recall a chirp. Just a normal idle.
I started hearing mine around 650 miles, after driving to a friends house when it was like 100 degrees out.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
