#1009 | |
Drives: FT86
The OFT ZA1JV01D00G tunes are actually based on ZA1JK01I roms fo use those to look at stock tavles, there is no opensource defs for the ZA1JV01D00G |
#1010 |
Drives: 2015 GT86
Hey guys,
I've run into a small issue, I come from the Evo tuning world (ECUflash and Evoscan) been playing around with it for over 6 years now. I've also done a few 86/BRZ's for mates. They were all auto's so they were A00I or A01I. i'm trying to help another mate out with a 2012 manual, when I pulled the ROM off his ECU in ECUflash it came up as a A00G and it will not let me change or edit any parameters. I've read on here that its okay to flash a A01G over the A00G, however in ECUflash when I pulled the ROM it says that it inherits the 16BITBASE file, the A01G that I found on here inherits the 32BITBASE. Will this be an issue when editing and reflashing? Also in the definition I have (from ECUFlash) the 3 ID's don't match up in the xml definition file itself, it looks like this: <romid> <xmlid>ZA1JA01G</xmlid> <internalidaddress>8000</internalidaddress> <internalidstring>ZA1JA01G</internalidstring> <caseid>8644387107</caseid> <ecuid>ZA1JA01C</ecuid> <make>Subaru</make> <market>AUDM</market> <model>BRZ</model> <transmission>6MT</transmission> <year>2012</year> <flashmethod>subarubrz</flashmethod> <memmodel>SH72531</memmodel> <checksummodule>subarudbw</checksummodule> </romid> <include>32BITBASE</include> As you can see the xmlid, internalidstring is different to the ecuid Which is why I have been reluctant to flash the ECU at the moment using the definition files that I have. If anyone is able to help out, that'd be great |
#1011 | |
Drives: FT86
A01G is compatavle with A00G , its the factpry update jist ise A01G rom and A01G definitions The A01C reference is a mistake it should be A01G Generally i do all my editing in Romraider then jist use ecuflash to do the flashing |
#1012 | |
Drives: 2015 GT86
Alright thanks mate, I've used the definition files from Github, and they seem to be a bit better. I'm really familiar with ECUflash for editing so I'll stick with that for now I think. Thanks for the advice however |
| The Following User Says Thank You to delza_6170 For This Useful Post: | steve99 (10-12-2021) |
#1013 | |
Road-hole
Drives: 2013 Whiteout FR-S
before giving up on a bricked ecu...
I had freaked out once because my laptop died half way through a flash and then the car wouldn't do anything. After doing the above, it worked fine and I was able to finish the flash. Jaden |
#1014 | |
Drives: 86 GT
I've been very careful thus far, several flashes done on mine and others' cars but would be good to have a fail-safe option when the need arises.
DIY stuff at Compelica Works
| The Following User Says Thank You to Compelica For This Useful Post: | Jaden (12-27-2021) |
#1015 |
Drives: brz 2017 hksv2
with ecutek you can t brick the ecu, while you have the licence in the ecu
ecutek software as an option of manually select the ecu and override the part-flashed brick error, you don t really need the support for this |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Compelica (12-28-2021) |
#1016 |
A few questions
Flashing OFT v4.03 and found A01G is the base rom with 3 matching addresses. Can I flash this rom into B01C car (2013 Canadian BRZ 6MT)
If Flashing this file would I use the A01G definition posted in the github? When I use the A01G definition and load the OFT v4.03 in ECUflash I see proper values in open loop and base timing tables. Is it safe to say the flash is safe from here? |
#1017 | |
Drives: FT86
yes you can flash A01G roms to B01C car its compatable |
#1018 |
Drives: 15 FRS
15 usdm frs MT ecu flash definitions
I have been trying to find the definitions for romraider or ecu flash so I can begin tuning but I keep finding mixed info.
Also if anyone has a map for a 15 USDM FRS MT with an Intake & Cat back, I would be much appreciated |
#1019 | |
Drives: FT86
Whats the ecu calubration id ? 2015 manual usa car you can use a ZA1JA01G as as substitute its well defined |
#1020 | |
Drives: 15 FRS
Edit. I pulled my room but it says rom unknown Last edited by 15WhiteFRS; 02-05-2022 at 01:52 PM. |
#1021 |
Drives: FT86
#1022 |
Optimizing tune
Hi I've flashed stg 1 OFT v4.03 and I'm trying to optimize this for 91 Canadian gas. In my logs I see -1.05 FBKC and positive 0.7 FLKC at the same time. (27xx rpm, 0.6g load). Should I decrease timing here or do nothing. IAM is 0.7.
https://datazap.me/u/legendz6/positi...ata=1-13-18-19 |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 01:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 11:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 09:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 08:27 AM |
