Drives: '13 FRS
ABS tone ring tooth count
Does anyone know the tooth count for the wheel speed sensors?
Looking at using a MK60 ABS and wondering if they are compatible-ish. |
#2 |
What part of the ABS are you considering? I don't know the number of poles but I'm curious.
#3 |
ProCrastinationConsultant
is there somewhere that specifies what the mk60 module requires? i'm not seeing any specifications other than which vehicles it's 'compatible' with.
#4 |
Drives: brz
I think its 48. It was posted somewhere on here, they said it was the wheel seal that is the reluctor. Magnetic strips embedded in the wheel seal.
| The Following User Says Thank You to brzlegend For This Useful Post: | soundman98 (10-02-2021) |
#5 | |
Drives: None
I'm running the MK60 in a Miata, I'm kind of curious why someone would want to convert the FRS/BRZ.
| The Following User Says Thank You to RedReplicant For This Useful Post: | soundman98 (10-02-2021) |
#6 | ||
Drives: '13 FRS
Looking at wiring diagrams last night, realized they are mag sensors and a not a shape that I've been able to find a hall sensor replacement for, so was considering Motec DMC-Bs to convert them to hall outputs for the MK60. I've read in a few places the MK60 would read pretty much anything as long as its maps are adjusted correctly for the overall parameters of the car. |
| Android Device with Blue tooth | mxrider404 | Electronics | Audio | NAV | Infotainment | 8 | 08-23-2014 11:25 PM |
| Blue tooth drop out | brze86 | Electronics | Audio | NAV | Infotainment | 62 | 03-13-2014 01:10 PM |
| iphone IOS 7 blue tooth | Garstang | Electronics | Audio | NAV | Infotainment | 42 | 11-01-2013 09:15 PM |
| how do you sync an iphone to the blue tooth in the car? | pr086 | Electronics | Audio | NAV | Infotainment | 5 | 12-06-2012 09:51 AM |
| Brand new FT-86 video w/ring tone link - Final reveal | ezmayo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 12-01-2011 06:40 PM |
