Old 10-01-2021, 10:57 PM   #1
adrianj73
Drives: '13 FRS
ABS tone ring tooth count
Does anyone know the tooth count for the wheel speed sensors?
Looking at using a MK60 ABS and wondering if they are compatible-ish.
adrianj73 is offline   Reply With Quote
Old 10-02-2021, 12:00 AM   #2
What part of the ABS are you considering? I don't know the number of poles but I'm curious.
Old 10-02-2021, 12:14 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
is there somewhere that specifies what the mk60 module requires? i'm not seeing any specifications other than which vehicles it's 'compatible' with.
Old 10-02-2021, 04:22 AM   #4
brzlegend
Drives: brz
I think its 48. It was posted somewhere on here, they said it was the wheel seal that is the reluctor. Magnetic strips embedded in the wheel seal.
brzlegend is offline   Reply With Quote
The Following User Says Thank You to brzlegend For This Useful Post:
soundman98 (10-02-2021)
Old 10-02-2021, 02:26 PM   #5
RedReplicant
Drives: None
BMW uses 48 tooth rings, but the sensors are magneto resistive rather than hall or reluctor. I'm not sure what the stock BRZ is, so that will also need to be taken into account.
I'm running the MK60 in a Miata, I'm kind of curious why someone would want to convert the FRS/BRZ.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 10-02-2021, 08:51 PM   #6
adrianj73
Drives: '13 FRS
I'm not entirely sure yet what I'm after from the OEM ABS, new to the platform (car isn't even here yet), but reading that people are having difficulty getting the VSC off. None of the OEM electronics or drivetrain (maybe diff) will remain at all, except possibly the steering sensor and ABS. Not sure which modules read the inputs for the pedal dance, but I'm not keeping spare stuff in just for that. I have several MK60s laying around anyway, but have never gone the standalone with them.
Looking at wiring diagrams last night, realized they are mag sensors and a not a shape that I've been able to find a hall sensor replacement for, so was considering Motec DMC-Bs to convert them to hall outputs for the MK60. I've read in a few places the MK60 would read pretty much anything as long as its maps are adjusted correctly for the overall parameters of the car.
Android Device with Blue tooth mxrider404 Electronics | Audio | NAV | Infotainment 8 08-24-2014 12:25 AM
Blue tooth drop out brze86 Electronics | Audio | NAV | Infotainment 62 03-13-2014 02:10 PM
iphone IOS 7 blue tooth Garstang Electronics | Audio | NAV | Infotainment 42 11-01-2013 10:15 PM
how do you sync an iphone to the blue tooth in the car? pr086 Electronics | Audio | NAV | Infotainment 5 12-06-2012 10:51 AM
Brand new FT-86 video w/ring tone link - Final reveal ezmayo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-01-2011 07:40 PM
