#127 |
Well, until about 2035 anyway....
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#128 | |
Drives: '23 BRZ Limited
But just driving around without it on wasn't great either as it would smoke the tires through first two gears, and that was keeping it on Pilot Super Sports. |
#129 | |
Drives: ‘22 CWP
Ours was not quite so exciting lol, just a totally stock N55. Was still pretty quick though. |
#130 |
Drives: 2022 BRZ WRB
#131 | |
Drives: Shopping Mustang GTs and BRZs/86s
- Sam Houston, or something like that If that’s the way you feel you’ve gotta get them while you can; they ARE going away. Won’t be too long before the worst automatic (hooked up to an electric motor no less) will be better than the best PDK you can get today. And that’s just until the robots take over driving completely. |
#132 |
TRACKBREAD
I want a low speed/high torque (10,000 rpm max) electric motor in a sports car with a 6-speed manual.
#133 | |
Drives: VW GLI 6MT
This thought could easily highjack the thread. Would a typical EV car benefit from having gears? Didn’t Tesla once use a 2 speed? What is the shape of an EV torque curve? What is the rpm range? If max rpm is 20,000 and the torque curve starts to decrease around 10,000 rpm, would gearing that keeps the motor in the 0 to 10,000 rpm range improve acceleration? Would lower rpm mean anything to an EV on the highway? Would the EV’s huge torque off the line shred a transmission? Would a CVT work? |
#134 | |
TRACKBREAD
The 2nd gen BRZ will have similar performance to…?
It makes no sense since the torque curve of an electric motor is [ideally linear] and they can do 100k rpm if designed for it. (not flat as I said before, so maybe it does make some sense.) But I want one. It would be so cool. Gotta find a way to make it loud under high current draw. You’d have to run a motor that’s an outrunner (rotor on the outside of the windings) than an inrunner style, so it would be shorter and bigger diameter, which would lower the RPM and increase the torque for a given power draw. Last edited by Yoshoobaroo; 09-15-2021 at 04:46 PM. |
#135 | |
Drives: 22 BRZ
Not flat, loses torque the higher you rev. This is a model S p85. https://www.dragtimes.com/2014-Tesla...phs-27027.html
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#136 |
Drives: 2022 GR86
That.
For acceleration, you want the engine to be as close as you can to max power (not torque) whenever you're flooring it. If the graphs above are correct, the Tesla's torque curve is only "flat" at low rpm, then it's the the power curve that is "flat", then both go down. For max acceleration, it is useful to keep the Tesla engine in the ~4000–9000 rpm range. Not too different from an ICE engine, if you think about it. There are however other reasons why a gearbox might not be that useful. It adds weight, points of failure, and you'd need N of them if you have N engines. It could be interesting if something like an NE/NF Miata EV or a Lotus EV had a lightweight electric engine with ~300 hp in the 4000–9000 range, and an old school gearbox. Porsche Taycan has two gears, I believe. |
#137 |
Drives: 2022 GR86
Forgot to mention: unless you have so much torque at low rpms that you're traction-limited, which is the case for high performance Teslas.
#138 |
TRACKBREAD
#139 |
Drives: 2022 GR86
Imagine operating two gearboxes at the same time
#140 |
Drives: 22 BRZ
| BMW 135i or similar | 8RZ | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 11-22-2019 11:33 PM |
| Considering Lemon Law or similar | TheMedakaBox | Issues | Warranty | Recalls / TSB | 28 | 08-31-2016 09:25 PM |
| Similar Wheels | calidus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-10-2014 01:46 PM |
| Who has a similar STI lip (PIC INSIDE) | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 05-02-2014 11:53 PM |
| Similar to JPM CoachWorks in Aus? | Egyptn | AUSTRALIA | 6 | 11-05-2013 10:44 PM |
