Old 08-31-2021, 04:41 PM   #1
gpvecchi
gpvecchi's Avatar
Information on ATI harmonic balancer
Do you know how the weight of the ATI damper compares to stock one, and if the diameter is the same?
Thanks!
Old 09-02-2021, 04:31 PM   #2
CSG Mike
CSG Mike's Avatar
It is heavier, and the diameter is identical.
gpvecchi (09-02-2021)
Old 09-02-2021, 08:19 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
7.07" diameter is 10% underdrive compared to the stock FA20 crank pulley
6.2lbs vs stock 4.87lbs
The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post:
CSG Mike (09-02-2021), gpvecchi (09-03-2021), Yoniyama (09-08-2021)
Old 09-03-2021, 08:45 PM   #4
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Consider the Fluidampr. As an owner I’m very impressed..
Bodalenko is offline   Reply With Quote
The Following 3 Users Say Thank You to Bodalenko For This Useful Post:
CSG Mike (09-07-2021), gpvecchi (09-04-2021), Yoniyama (09-08-2021)
Old 09-09-2021, 07:42 AM   #5
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Would you be able to quantify the change? Is it easily perceived?
Thanks.
Thefalls is offline   Reply With Quote
Old 09-09-2021, 09:57 AM   #6
86TOYO2k17
Thanks.
Not at all.
Unless you are the type of person to add a catback pick up maybe 1whp and say you noticed a dramatic seat of the pants butt dyno improvement to performance lol. The improvement to "smoothness" really isn't noticeable.
There is some testing data, and sound theory/logic behind the concept and what it does, and that it should be beneficial. but realistically there is little point especially if you are NA and/or stock block.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Dzmitry (09-09-2021)
Old 09-09-2021, 04:17 PM   #7
gpvecchi
gpvecchi's Avatar
Thanks everybody, but definetly not interested in putting in a heavier pulley than stock.
Fluidampr harmonic damper - for race/track only use - Experiences? prandelia Tracking / Autocross / HPDE / Drifting 14 03-02-2020 07:34 PM
Harmonic Resonance/vibration question prandelia Tracking / Autocross / HPDE / Drifting 42 12-26-2019 03:42 PM
ATI Harmonic Dampner JJD28 Engine, Exhaust, Transmission 19 07-03-2017 06:14 AM
Harmonic Noise from rear Differential at 69 MPH solved Avion Engine, Exhaust, Transmission 0 01-28-2016 09:51 PM
Information I did not want to know. K2 Great Lakes 19 07-23-2012 09:18 AM
