Old 03-31-2021, 09:33 PM   #29
Vital
Drives: 2015 BRZ
Originally Posted by billstock67 View Post
Installed Pedders, along with B6 & Yellow springs. Front camber is L -1.34°, R -1.78°, without crash or camber bolts. Preloaded everything to maximum camber direction before tightening, to take advantage of normal clearances.
Would you be able to upload some pics? I just wanna see how the car looks with the B6 and RCE Yellows. TIA!
Old 03-31-2021, 09:37 PM   #30
billstock67
Drives: 2017 Toyota 86
I'll try this weekend.
billstock67 is offline   Reply With Quote
The Following User Says Thank You to billstock67 For This Useful Post:
Vital (04-01-2021)
Old 09-06-2021, 06:57 AM   #31
AndMsc
Drives: MY2018 GT86 EU
Is it possible to only gain camber with these? (Without caster gain)
AndMsc is offline   Reply With Quote
Old 09-06-2021, 01:50 PM   #32
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
No.
BlueWhelan is offline   Reply With Quote
Old 09-06-2021, 01:57 PM   #33
Calum
That Guy
Drives: 2013 asphalt FRS MT
A little more caster isn't a bad thing though. My FWD Golf RUNS more caster from the factory.
Sent from my Pixel 4a (5G) using Tapatalk
Old 09-06-2021, 11:05 PM   #34
DarkSunrise
DarkSunrise's Avatar
Normally not, but I think it might make the EPS steering cut issue worse on our cars.
2022 BRZ Build
2013 FR-S Build
Old 09-07-2021, 05:01 AM   #35
AndMsc
Do all GT86s have the EPS issue? Or only certain years? Mine's a MY01/2018.
Old 09-07-2021, 10:36 AM   #36
churchx
churchx's Avatar
Drives: 2014 GT86
Then you should have no problems. It was improved/fixed .. i don't recall when exactly, was it ~ MY2015 or MY2017 restyle, but your, as restyle one, shouldn't have it for certain.
Old 09-07-2021, 11:19 AM   #37
86league
Drives: '13 BRZ Limited
Think it was for the 2017s or later, I have a friend with a 2016 that has the EPS cut problem on track.
86league is offline   Reply With Quote
Old 04-23-2022, 01:14 PM   #38
wparsons
wparsons's Avatar
For anyone that had these a while ago, how are they lasting? Holding up well a year+ later?
flickr
Old 04-23-2022, 03:47 PM   #39
BlueWhelan
BlueWhelan's Avatar
Pedders Top Hats - Add camber without sacrificing wheel clearance
Pulled em off because they weren’t legal in my class, but they held up great! Highly recommended
I still have the set
The Following User Says Thank You to BlueWhelan For This Useful Post:
wparsons (05-02-2022)
Old 04-23-2022, 03:56 PM   #40
7 skulls
Drives: 2014 scion frs
I've had them on since 2020. No problems so far. About 20 000km.
7 skulls is offline   Reply With Quote
The Following User Says Thank You to 7 skulls For This Useful Post:
Old 04-27-2022, 06:07 AM   #41
dasting
Drives: 2013 BRZ Limited
Yeah, 18 months, a few track days, and about 15k street miles and they’re still good as new.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
The Following User Says Thank You to dasting For This Useful Post:
Old 04-27-2022, 06:36 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
With generally positive experiences, makes me think, why it was so hard for whiteline to get it right in past.
Ohio Enthusiast (04-27-2022), wparsons (05-02-2022)
Pedders top hats and subaru camber bolts... results. 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 02-01-2021 06:24 PM
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 04:35 PM
FS: RCE T2 Coilovers w/RCE Camber Plates and MSI Top Hats jprice130 Brakes, Suspension, Chassis 4 09-23-2016 09:36 PM
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder MyRx Brakes, Suspension, Chassis 5 10-12-2014 02:14 PM
