Drives: black
I was reinstalling the negative terminal clamp back onto the battery when the bolt snapped and the clamp went loose. Obviously I cannot drive anywhere like this and was wondering if anyone on here knows the part number or a viable replacement for the terminal. I know that we have a special clamp with some type of sensor next to the copper wire.
#2 |
TRACKBREAD
Need Battery Information ASAP
I think Bubba would suggest a bolt and nut combo that fits in the hole. Leave the connector be.
What do you think @? |
#3 |
Drives: Crapcan
Take broken pieces to Napa. Ask for comparable part, it may not be exact but it will be close enough. Likely standard and not metric.
#4 |
Master Collaborator
Bubba would be right. And clean all of that corrosion off while you're in there. And why is that red wire cut?
#5 |
ProCrastinationConsultant
i lost my bolt like that a while back. it's a generic subaru bolt. the replacement i got was listed for an outback or something. talk to any of the auto parts stores. they'll have something that will work.
it's just a bolt with a fancy end on it, trick is to not tell the car you're using a different bolt, and it'll never know the difference!
| The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (09-07-2021) |
#6 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
If you can't find the exact bolt I would think you can buy any terminal and just use the bolt from it
#7 | ||
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
This is not a permanent fix and you should replace the bolt as suggested above by other responses My point is there is no problem driving the car short distances without the bolt (like to the parts store and back). If the connection is loose the most likely "failure" is that you battery won't charge well and eventually you will not be able to restart and require a jump.
| The Following 2 Users Say Thank You to nextcar For This Useful Post: | soundman98 (09-04-2021), Yoshoobaroo (09-04-2021) |
#8 | |
Drives: Scion FRS 10 series
23775AA060 |
| The Following User Says Thank You to Project_1796 For This Useful Post: | soundman98 (09-05-2021) |
#9 | |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Dzmitry (09-08-2021), soundman98 (09-05-2021) |
#10 |
^that works in 3 ways.
it fastens down the battery clamp it will keep you warm in the winter and it will guarantee you'll need a new car!
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (09-06-2021) |
#11 |
Pavement Grey
| The Following User Says Thank You to Sasquachulator For This Useful Post: | soundman98 (09-08-2021) |
#12 |
Funny, I would have never even thought about getting an "official" bolt. I would have dug through my collection of odd bolts, nuts and washers, found one that fit through the hole and moved on. I guess I have a little too much Bubba in me as well.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | bcj (09-08-2021), humfrz (09-07-2021), pope (09-09-2021), soundman98 (09-08-2021), Yoshoobaroo (09-07-2021) |
#13 | |
TRACKBREAD
I think that’s just the right amount of Bubba. It’s a perfectly fine repair that won’t affect anything else. |
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | Dadhawk (09-07-2021), soundman98 (09-08-2021) |
#14 |
6 mm hex head cap screw, two washers, split lock washer, and nut.
Clamp the washers together, and file, sand, grind a flat on their sides deep enough to fit properly onto your terminal connector. If you're patient and handy enough, you can bend up the orthogonal sides of one of the washers to make a saddle for the screw head so it can't rotate while you tighten the nut.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Tags |
| battery, battery clamp, battery disconnect, battery repair |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 01:55 PM |
| Cheaper lighter battery option - Miata battery | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-06-2017 06:51 PM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 01:07 AM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 01:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
