Old 08-23-2021, 11:21 AM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Right turn signal dims out a bit
I currently run TOMs tail lights with stock BRZ (2013) headlights that have an LED turn signal mod on them. The flasher relay I currently use is a DiodeDynamics tap-turn module.
It's been fine for 2 years but lately when using the turn signals, the right one would go on normally then dim for a split second, at first I thought it was my tail light bulbs, but the front is doing it too as well as the lamp on the cluster.
There is no hyperflashing, just slight dimming when the signal comes on. This issue doesn't happen when the hazards are on which is what led me to believe it's not a bulb issue.
Any advice is appreciated here, thanks!
scottryan is offline   Reply With Quote
The Following User Says Thank You to scottryan For This Useful Post:
humfrz (08-23-2021)
Old 08-23-2021, 03:26 PM   #2
Looks like a job for @soundman98
scottryan (08-29-2021)
Old 08-23-2021, 09:17 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would pick up a replacement led flasher first-- easiest to replace, and if it's front/back, the most likely culprit.
Old 08-29-2021, 07:38 PM   #4
scottryan
Financial Distress
scottryan's Avatar
Thank you, I actually have the relay from the TOMs lying around, will throw it on and see if it's the culprit. I appreciate the help
Turn signal cancelling/turn off issue Koi Issues | Warranty | Recalls / TSB 5 10-18-2020 11:19 PM
Right side turn signal does not turn on Feargt86 Issues | Warranty | Recalls / TSB 4 10-02-2018 02:10 PM
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 12:51 PM
Installed Third Brakelight Kit, Clock Completely Dims / Airbag Slightly Dims FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 01-26-2016 03:37 PM
