#295 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I referenced the SMG because as it's still technically a manual, there are bound to be some who'd justify that choice with a "bububut motorsport!" argument, while in real life in a road car, an SMG or as you said, even a DCT does't even have a clear advantage over an AT. But I'll tell you what though, for all their failings, I still like the feel of the SMG-II in the E46 M3 and E85 Z4, there's a "chill-ness" to it driving around slow in the softest mode. The damn thing tries so hard to be smooth it starts in 2nd :lol |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Yoshoobaroo (08-22-2021) |
#296 | |
Drives: 2014 Mazda CX-5
For whatever reason, I need to go auto with my GR86. What I'd really like to hear is some real world non-track reviews of the Gen2 AT. This car will never feel the asphalt of a track (maybe if I take up the free track day that Toyota is offering and I'm within 3 hours of Lime Rock so that's a possibility) but I want to know how much fun I'll be losing, if any, while doing some spirited driving on local roadways with the AT vs the manual. |
#297 |
Drives: WR Blue Pearl 2022 Subaru BRZ
The auto in the GR86 is quite an old style one, that essentially uses liquid to engage the gears (imagine a water wheel - kind of), what that means is that there is always a bit of a lag because the transfer of liquid and build up of torque is slow.
There is a great variation in how good/bad these type of autos are. The GR86 has a really good one, so its not to 'slushy' or 'laggy', and the electronics are really quite good at doing the right thing on the track - which is NOT easy for a car with comparable (to sports cars) low power. High performance cars might have worse electronics but you wouldn't know because they just have so much power in all the gears. DSG and the other things are essentially like robotics made to change gears using a clutch - they can generally always beat a human because they cheat, and are not limited to working with just one clutch ![]() Neither as as quick and not _quite_ the brutal engagement of a dog box on a sequential manual though - they will always be faster, but they are really track and racing only. Auto or not, this is the ultimate drivers car (within reason) - your still rear wheel drive and still running on this magnificent low and tight platform. One thing about auto's though - dont stick to the book for changing your automatics transmission oil. Unlike a manual, they a FUCKING EXPENSIVE to fix, and while transmission oil isn't cheap, do not hesitate to get it replaced at half the interval it says for you to to. These older autos will last forever if you just keep replacing the oil fairly regularly. Last edited by Blighty; 08-22-2021 at 11:02 AM. |
| The Following 2 Users Say Thank You to Blighty For This Useful Post: | StE92ve (08-22-2021), Yoshoobaroo (08-22-2021) |
#298 |
I wonder if they have done the BRZ drives yet?
Everyone was saying it was 2 weeks away at the GR86 day, and that was like the 8th or 9th. Its exactly two weeks now! |
| The Following User Says Thank You to Blighty For This Useful Post: | Yoshoobaroo (08-22-2021) |
#299 | |
TRACKBREAD
This cannot be overstated. I helped a friend troubleshoot a 90s ZF box in a BMW. 200,000 miles on the original fluid. It was dropping shifts and tried to engage REVERSE at the same time as 5th gear. We flushed the fluid and replaced the filter, and then again after a few hundred miles. Ran like a champ after that. |
#300 |
Sure some autos suck, and some MTs suck too.
#301 | ||
It's not uncommon for the oil pan to hold about half of the oil capacity, so they are quite right: A pan drop & fill at half interval will be the easiest way to keep all of the oil fresh and new enough at all times. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Blighty (08-22-2021) |
#302 |
I don't know Martin Padgett but this is what he says about the auto in the GR86:
https://www.motorauthority.com/news/...ew-photos-info "I’m better with the automatic—everyone and anyone would be, and should be—as I slap it sideways into its manual-shift mode, and point and shoot through corners. The brakes help calm the few ripples in the 86’s eager demeanor; they’re not particularly numb or sharp, but they brush off speed efficiently and settle the car into long sweepers. The automatic doesn’t like to let the engine reach full bore, and when you try to hit redline it rings and dings and denies the shift. Still, it’s best kept in manual mode and flipped through the gear range with paddles, Buy the automatic if you intend to drive the GR86 mostly on open roads, if only for the safety gear it gets that manual cars do not (automatic emergency braking, for starters). It’s fine, but switching back into a Premium car with the 6-speed manual and 215/40R18 Michelin Pilot Sport 4 tires reveals the car Toyota engineers want everyone to track, every weekend. It has the extra grip that encourages deep and late braking. That builds confidence, and though my feet still klutz it up once or twice, the training wheels eventually bring me to a smooth-shifting, single-lap Monticello blitz before it’s all done. It’s really good as an automatic; as a manual, the GR86 is the senior-year achievement test that places you in graduate school (Supra, and higher)." |
#303 | |
TRACKBREAD
What a weird take. Picking a transmission has nothing to do with where you plan on driving it. Street or track doesn’t matter. Get the auto if you want the auto, get the manual if you want the manual. It’s that simple. |
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | soundman98 (08-23-2021), spike021 (08-22-2021) |
#304 |
The Dictater
Drives: '13 Red Scion FRS
That's a strange way of saying "Just get the auto if you can't drive stick".
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#305 |
Guest
Posts: n/a
There's no excuse good enough for going automatic in an 86. Unless you are impaired and physically cannot drive one lol. It doesn't need Rev matching either. That's not fitting with the ethos of the car. And definitely not purity imo.
#306 | |
If I were buying a 2022 86, which I'm not for reasons I've stated, I would consider the MT this time, but only because they didn't add the one thing the AT needed, launch control. However, I do not regret a single one of the 190,000+ miles I've put on my AT FRS. Having a manual would have added nothing to the experience.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 08-22-2021 at 07:13 PM. |
| The Following 6 Users Say Thank You to Dadhawk For This Useful Post: | Blighty (08-22-2021), Ernest72 (08-22-2021), humfrz (08-23-2021), soundman98 (08-22-2021), StE92ve (08-22-2021), Yoshoobaroo (08-22-2021) |
#307 |
Guest
Posts: n/a
Then good for you. I would cry it I had to have an automatic and simply sould not want it. Again, imo, no reason good enough. Bunch of rationalizations but not valid. Again, imo. And i am buying one. Because I'm a purist and truly know how to drive
#308 |
ProCrastinationConsultant
i'm still pissed that they removed the manual spark advance from the concept!
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
| GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 07-18-2021 04:38 PM |
| Real World MPG | Be-Are-Zee | BRZ First-Gen (2012+) — General Topics | 302 | 07-13-2014 04:06 PM |
| Full Report: Road & Track tests stickier FR-S/BRZ tires | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 74 | 08-15-2013 02:10 AM |
