08-21-2021, 11:04 PM | #225 |
Drives: 2013 FRS
Sign up for their mailing list, they're supposed to release the kit within the next couple weeks and will notify list members.
08-21-2021, 11:55 PM | #226 |
Drives: Q5 + BRZ + M796
I was told back in May there would be a preorder list in June for a July release. When that didn’t happen, I asked on my wife’s IG if the release slated for the end of August was for buying or for getting on a preorder list. No response. I wouldn’t hold your breath on the kits being available soon. My wife said one guy commented that he bought a kit three months prior and still was waiting on shipping, which he deleted or they deleted. Little fishy.
08-22-2021, 01:52 PM | #227 | |
Drives: 13 White MT FR-S
But here you go: https://www.tts-performance.co.uk/si...type-r-diy-kit
08-30-2021, 02:56 PM | #228 |
They are dropping the kit tomorrow, 8/31/21. Information below:
https://kpower.industries/blogs/news...6-swap-is-here
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | BrahmaBull1990 (08-30-2021), jflogerzi (09-04-2021) |
08-30-2021, 03:32 PM | #229 |
Drives: Crapcan
Now watch the parts be backordered for 6 more months
08-30-2021, 04:06 PM | #230 | |
Howdy
Drives: 2020 BRZ PP
What's more economical for an "improved car?" The NA specs are enough to keep me with a stock K24 since it's similar to my FA20 + Edelbrock... Is this more reliable than a staged FA20 short block? K24s are pennies compared to a FA20.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
08-30-2021, 05:06 PM | #231 | |
Stock, the K24 will do 450whp compared to the FA20's 350whp, but it has more displacement. The FA24 might do 450whp, but I doubt it will be as reliable in all applications unless they fix some stuff. The K24 is easier to build and service and configure. The K24 will be cheaper to replace and cheaper to build, and it will have more aftermarket support. Swaps are expensive though, so there is little way around that. This only becomes economical at the extremes, and it isn't for most people. It will depreciate the car more in almost all cases, and it will make the car illegal in many states.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | BrahmaBull1990 (08-30-2021) |
08-30-2021, 05:13 PM | #232 | |
Howdy
Drives: 2020 BRZ PP
08-30-2021, 05:15 PM | #233 |
On another note, I emailed Kpower about the hydraulic release bearing they mentioned in emails and showed, but didn't include in the blog. I sold my fork and pivot based on those things, but it seems like those items can be reused with their adapter design. Regardless, I wanted the hydraulic setup because my snout was replaced once already and is already worn, and the upgraded (white dot, MY17+) TOB was already jacked.
Their header and midpipe might align with the frontpipe or with the catback. Looking for clarification. They have two o2 sensor locations, but they only mention one Bosch Wideband sensor, so looking for clarification. I like the use of everything else like the mounts and things, but I need to do a custom order because I have a lot of stuff. I think I will be utilizing the steel flywheel and not the aluminum flywheel for better street-ability. I have a turbo, so I don't need to rev fast. Hopefully shipping doesn't take forever.
08-30-2021, 08:51 PM | #234 | |
They also said the hydro TB would come later.
The Following User Says Thank You to ML For This Useful Post: | Irace86.2.0 (08-30-2021) |
08-30-2021, 09:51 PM | #235 | |
I looked again, and I guess it does say the hydraulic TOB will come down the road with the stronger transmission option, but I don't know if that TOB is for the new transmission or for both. Kind of lame to have to wait for it or have to buy back new what I sold used based on their comments.
08-30-2021, 10:34 PM | #236 | |
08-31-2021, 02:04 AM | #237 | |
I won't be using that intake.
08-31-2021, 11:10 AM | #238 |
Howdy
Drives: 2020 BRZ PP
PRICES UP!
$10k for the complete swap…$10.5k if you want AC and heat…personally, I will be sticking to the plan of a stage 2 FA20 short block. https://kpower.industries/collections/kpower-86-swap
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
