Old 08-20-2021, 03:23 AM   #15
Iffen the AC is blowing cold air and the compressor ain't smoken - it ain't broke - no need to fix it.
from Bubba
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Opie (08-20-2021), soundman98 (08-20-2021), Ultramaroon (08-20-2021), Yoshoobaroo (08-20-2021)
Old 08-20-2021, 07:10 AM   #16
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Ossiko View Post
Well I’m not sure, because when he said this to me, and I know nothing about cars, so it was concerning to me. It blows cold air perfectly fine, when the car is in idil, the engine runs, then for a second as the compressor cycles you can hear your RPMs drop a bit, then it picks up again, and the cycle continues etc. Weather was about 80ish degrees and humidity was about 80-90% so I wouldn’t think the ambient had anything to do with it, but I could be wrong
Ambient conditions have EVERYTHING to do with AC performance. 80 degrees and nearly maxed humidity is a decent load on an AC system, if your air outlet temp is in spec, it's likely fine. To test your air outlet temp: Hood closed, windows down, MAX AC setting and max blower speed, 1500 RPM, let you thermometer stabilise.
Old 08-20-2021, 10:26 AM   #17
Vital
Drives: 2015 BRZ
DO you have an automatic? There is a TSB for idle stability the Autos when they are in Park or Neutral. Otherwise i know there was another TSB for idle stability for Autos and Manuals.
https://www.tsbsearch.com/Subaru/11-136-14
Old 08-20-2021, 08:09 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by FR-S2GT86 View Post
You should tell us the name of the shop and the city where this mechanic works so that we all know to stay away from it.
that does about as much good as 'blocking' those spoofed spam callers. if the guy's terrible, much of the time he'll end up bouncing around to another shop in a few weeks time, and all we end up doing is smearing a small business name in the dirt over an employee that they already dealt with.
FR-S2GT86 (08-21-2021)
Old 08-20-2021, 09:50 PM   #19
It’s blowing cold air, that’s why I don’t get it.
Here's why it's normal. There's a temp sensor on the evaporator (in the cabin) The controller shuts off the compressor to keep it from getting too cold and frosting. Test it by cranking the blower to high. It'll quit disengaging because the evaporator can't get cold enough.
Did someone else already answer this? Meh.
humfrz (08-21-2021), soundman98 (08-20-2021), x808drifter (08-21-2021)
Old 08-21-2021, 01:10 AM   #20
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
as a professional wrench, its perfectly normal for it to cycle on and off. If its every few seconds it might be either over pressure or under pressure, but other than that, normal. if it sounds normal, and the clutch doesn't appear overly rusty in the contact surfaces(with associated rust all around when it gets worse), and its not noisy, along with the system making cold air, its fine.
If your mechanic said you might need a new compressor based on the compressor cycling, he is either incompetent, or trying to rip you off.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 08-21-2021, 02:12 AM   #21
As they say "the short term memory is the second thing to go" -
Ultramaroon (08-21-2021)
Old 08-21-2021, 02:34 AM   #22
What's the first?
humfrz (08-21-2021), MuseChaser (08-21-2021)
Old 08-21-2021, 05:40 AM   #23
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
What's the first?
Probably ED
Sur is offline   Reply With Quote
The Following User Says Thank You to Sur For This Useful Post:
humfrz (08-21-2021)
Old 08-21-2021, 03:46 PM   #24
Originally Posted by Sur View Post
Probably ED
lol ... I mean Awww...
humfrz (08-21-2021)
Old 08-21-2021, 03:58 PM   #25
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I appreciate how you compare incompetent mechanics to spam callers.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
soundman98 (08-21-2021)
Old 08-21-2021, 05:58 PM   #26
What's the first?
Old 08-21-2021, 06:39 PM   #27
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
What's the first?
The first what?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 2 Users Say Thank You to MuseChaser For This Useful Post:
soundman98 (08-21-2021), Ultramaroon (08-21-2021)
Old 08-21-2021, 06:43 PM   #28
Originally Posted by MuseChaser View Post
The first what?
THAT'S what I was thinking.
AC Compressor Joesurf79 Engine, Exhaust, Bolt-Ons 8 05-28-2018 10:22 AM
AC Compressor Joesurf79 Engine, Exhaust, Bolt-Ons 0 05-22-2018 11:22 AM
Ls a/c compressor Parman Engine Swaps 1 11-20-2017 09:45 PM
AC compressor derek1ee Interior Parts (Incl. Lighting) 0 06-03-2016 02:17 AM
Air compressor for air tools? bleox Other Vehicles & General Automotive Discussions 17 12-30-2015 07:02 PM
