Old 08-03-2021, 05:27 PM   #1
haohmaru
Drives: Red 2024 GR86 Trueno
Compression and Leak Down Tests
Hey everybody, I did a cold compression test on #4 and it came back at 150, which according to everything I've researched is VERY low. So I then did a leak down test, but that came back with almost no leakage at all.
I'm also not having any smoke, CELs or rough idle. So is 150 ok? Car has 55K on it.
Thanks
haohmaru is offline   Reply With Quote
Old 08-03-2021, 05:37 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Thanks
What were the results from the other three cylinders?
And why are you performing a compression test? Are you having some sort of issue?
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 08-03-2021, 05:52 PM   #3
haohmaru
Didn't get to the others yet, probably tomorrow. And I'm just testing to see if engine is healthy enough for supercharging.
Old 08-03-2021, 06:09 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Gotcha. Yeah, the best thing to do is get data from all four cylinders before coming to any conclusions.
Old 08-05-2021, 09:53 PM   #5
haohmaru
OK, did compression tests on 1-3 and they all came back an even 150psi give or take a couple PSI. Also did a leak down test on #1 and it came back good, about 2-3%
I also tried a different gauge in case that was the issue and that came back 150 as well.
Old 08-06-2021, 11:08 AM   #6
haohmaru
I sent an email to my tuner shop who does Subaru's all day long, this is what they said:
"In general cyl to cyl consistency is the most important. If leakdown is that low and all cyls are similar I wouldn't worry about it"
Old 08-07-2021, 12:30 PM   #7
Grady
Grady's Avatar
Leak down/compression tests are good for troubleshooting issues and getting an idea of health if you do not know the engine. If you know your engine you are better off going by how it runs and controls the oil. AKA does not burn a lot.
Drive 'tests' the 2017 BRZ Guru Woodman BRZ Photos, Videos, Wallpapers, Gallery Forum 43 12-21-2016 09:43 AM
Hooniverse tests the 2017 86 Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 10-19-2016 02:15 PM
Moto IQ tests the KW V3... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 07-18-2013 04:44 PM
