Old 07-28-2021, 10:55 AM   #1
Darknd666
Drives: 2017 86
12v ignition source under hood
I am trying to find the 12v ignition source in the engine bay. I need to wire in my thermo switch for my oil cooler. Please help me find it, google has not been very useful and any other result tells me to run a wire inside he cabin...would there be any problems using an accessory power source in the engine bay? If so so where would it be?
Darknd666 is offline   Reply With Quote
Old 07-28-2021, 11:33 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Have you looked into an add a circuit fuse?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-28-2021, 04:55 PM   #3
Darknd666
Drives: 2017 86
Thats what im using, i tapped into the main A/B fuse, now my check engine light comes on for it, U0122
Old 07-29-2021, 10:57 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Move it to a different fuse?
Old 07-29-2021, 12:07 PM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Do you have and know how to use a multimeter? Find an unused fuse spot in the engine bay fuse panel that is switched on while the vehicle is running and switches back off when you shut the car off, and tap into that circuit using a fuse tap kit such as this one,
and then by adding a fused wire to the hot side (as opposed to the load side) of the fuse position.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Wally86 (07-29-2021)
Old 07-29-2021, 01:26 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I like using this style personally.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (07-29-2021), kevaughan (08-03-2021), soundman98 (07-30-2021), Wally86 (07-29-2021)
Old 07-29-2021, 11:08 PM   #7
Darknd666
Drives: 2017 86
Thats what i used, i will try another fuse, or ill use the other method mentioned and use an unused fuse socket the instructions for those add a circuits dont tell you the flow direction so if using two different fuse sizes it could damage things...thats why i targeted a 15amp fuse to match the 15 i was adding so it didnt matter the direction i inserted the product.
Old 07-30-2021, 05:03 PM   #8
Darknd666
Drives: 2017 86
Well the oil cooler fan pack works in an unused fuse spot, off of the bus bar, now to see if the code went away
The Following 2 Users Say Thank You to Darknd666 For This Useful Post:
jcw99 (08-01-2021), NoHaveMSG (07-30-2021)
Old 07-30-2021, 05:05 PM   #9
Darknd666
Drives: 2017 86
Problem solved t used to cut the CEL on after starting the car. You learn something new every day, a other thing is the engine would stay running for a few secconds after removing the key from ignition now it cuts off immediately after removing key, which was what was supposed to happen
The Following User Says Thank You to Darknd666 For This Useful Post:
SOLD: Seibon VS-Style Carbon Fiber Hood w/ Quik Latch Hood Pins sixthspeed Exterior Parts (Aero, Lighting, Etc.) 16 02-07-2021 09:49 PM
FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) iceblaze Southern California 1 04-14-2019 04:50 PM
Need help finding source of power without key in the ignition itsAlex DIY (Do-It-Yourself) Guides 11 04-16-2016 03:36 PM
