Drives: car
Fixing loose shifter
I have a loose shifter, which has been loose ever since I took my car to a shop for a clutch install 5 years ago. I have not figured out how to fix it, and have been checking previous pages on these forums to figure it out but we never got it. I don't really get under the car very often, so looking to see if somebody else has worked on this problem.
Does anybody know how to fix this. I'm trying to figure out what bushing or perhaps boot might be missing or might be torn/damaged. |
#2 |
You'll have to get underneath the car to find the missing or worn nylon bushing. That's all it is.
#3 |
Drives: 2013 FRS
here's a diagram
https://www.subarupartwholesale.com/...10-350-01.html could be a problem where the pivot pins go thru bushings. Maybe one of the cotter pins is missing and the pin is backing out, allowed bushing to wear badly. Possibly loose bolts or bushing at the rear where the shifter support frame mounts to the floor pan. Could be a number of things. I think if you get the under tray removed and have someone wiggling the level while you watch those points it will be obvious.
WIFE: "How can there be anything left to buy?"
#4 | |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 09:20 PM |
| Shifter is very loose and its very hard to find gears. | ZX88 | Issues | Warranty | Recalls / TSB | 5 | 03-18-2015 12:50 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| Why fixing your car is fun | OldSkoolToys | Other Vehicles & General Automotive Discussions | 134 | 05-04-2011 06:50 PM |
