Old 07-21-2021, 10:06 PM   #1
Darknd666
Drives: 2017 86
Flexible ABS lines for relocation
I want to relocate the ABS, but need flexible hydraulic lines. On the other hand removal is done with a kit and creates a knob for adjusting rear front brake pressure. If I were to remove the ABS and KEEP the brake booster would the CEL come on for the ABS or can ECUtek mod the ECU ROM to disreguard the ABS? I have converted a 02 Galant from automatic to manual before and paid a programmer to remove the Automatic solenoids from the ROM so I know this is a thing, but is it possible with this platforms computer?
EDIT: Another Thought, if I could get the sizes for the fittings on the ABS(VSC,VDC) module i could just make my own fittings and put it somewhere else in the engine bay?
My purpose you ask? The ABS is just in the way, I want a bigger air filter for my JDL turbo or at least more space so it doesnt rub against anything.
Darknd666 is offline   Reply With Quote
Old 07-21-2021, 10:39 PM   #2
Ashikabi
Ashikabi's Avatar
You can bend and flare new brake lines. Or adapt them all to AN
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
NoHaveMSG (07-22-2021)
WTB: STi Flexible V-Bars N_Raged Want-To-Buy Requests 2 06-12-2020 12:10 AM
FS (Chicago) - Winmax W5 Rear Pads, Spiegler Front Brake Lines, Stoptech Rear Lines Jamestl Brakes, Suspension, Chassis 4 01-10-2020 06:41 PM
FS: OEM STI Flexible V-Bars Ethereal05 Brakes, Suspension, Chassis 2 01-15-2018 04:19 PM
Flexible Draw Stiffener and Flexible Tower Bar Maxwell BRZ First-Gen (2012+) — General Topics 5 01-11-2015 12:43 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
