| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 14 brz
Hey guys! Im new to this forum and to cars as well (just got my brz back in january).
I have a question about going up a tire size/width. As you know, the stock tire dimensions are 215/45/17. Im planning on sticking with 17in rims, but want to know if there will be any issues if i go up to 225/45/17. What are the pros and cons? And will it throw off my speedometer? Sorry if these are dumb questions, Im such a newb lmao but I want to learn the most that I can! Any and all feedback will be much appreciated! |
#2 |
Drives: Crapcan
225/45/17 is fairly common to use. Your speedo will read lower then you are actually going.
#3 |
ProCrastinationConsultant
per wheel-it-fit.com, changing to a 225/45/17 means the tire diameter will increase from 625mm to 634mm, which would result in a speedo difference of -1.4km/h, which simply means at 60mph, the car will read about 0.5mph slower than actual.
which, my car and others in my families fleet consistently measures around 2mph slower according to speed signs anyways.
#4 |
Drives: 14 brz
#5 | |
Drives: 14 brz
#6 |
EcuTec can and I believe OFT will also. I have that tire size and a there is about a 1 to 2 MPH difference between Speedo and GPS at 70mph.
#7 | |
Tire compound grip is more based on other factors in the rubber and tread. Yes, there's going to be a slightly larger contact patch, but 10mm extra width isn't going to have a significant difference either way. I doubt one could even get much different in track times with that change. Might be good for 1/10 of a second at best
#8 |
Drives: 14 brz
#9 | |
Drives: 14 brz
thanks for the helpful info! everyone on this forum seems so nice
#10 |
Drives: 2014 FR-S
With a new set of Continental ExtremeContact 225/45-R17s my speedometer was right on the money (speedo gets more optimistic as tires wear). Manufacturers almost always calibrate speedometers to be 1-2 mph optimistic at 60mph to make sure they aren't responsible for you go over the speed limit.
| The Following User Says Thank You to tarzan_nojane For This Useful Post: | thomasmryan (07-08-2021) |
#11 |
Persona Non Grata
Drives: '15 BRZ (WRB)
On 7" wheels the 225 may be slightly pinched and as a result be a wee bit squishier on turn in. It may also ride a little smoother.
Slow is smooth, and smooth is fast
#12 |
If it’s just for DD, keep stock size for light weight and playfulness.
| Need some help with what tire size i should get. | sosky9 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-27-2018 04:20 PM |
| Tire rack giving me a hard time on tire size, so please help! | NOI | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-03-2017 06:27 PM |
| Tire compound vs Tire size | Dihudaxia | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-22-2015 10:55 AM |
| Help with Tire Size | Sivtec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-12-2013 12:40 AM |
| Tire Size help! | J-Money | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-04-2013 12:04 PM |
