#337 |
Gonna be scheduling time with Zach as CSG. Won't have before but I am sure they have a stock Dyno that we can add to compare. Will be getting 91 and e85 really dialed in
2013 Series 10 FRS #553
#338 | |
![]() Sent from my GM1915 using Tapatalk
| The Following User Says Thank You to jflogerzi For This Useful Post: | Mike_ZN6 (07-10-2021) |
#339 |
#340 |
Drives: 2016 Toyota 86
The car was tuned in person at PTuning by their master tuner, Toan. Last edited by Mike_ZN6; 07-10-2021 at 10:27 AM. |
| The Following User Says Thank You to Mike_ZN6 For This Useful Post: | gpvecchi (07-11-2021) |
#341 |
I noticed today that the overpipe on my car has started banging against the front subframe when the engine shifts towards the passenger side. After the install of the JDL 4-2-1, PTuning pointed out the clearance to the subframe was very close and they said this may be an issue.
PTuning has suggested placing some shims under the passenger motor mount to get some additional clearance. I am also thinking I should probably get some stiffer motor mounts like the STi units. Is this an install issue? Has anyone else had this problem? |
#342 |
Overpipes have always been a problem on this car. Is it stock or aftermarket?
#343 |
#344 |
Ahhh it's mostly aftermarket ones that can have clearance issues.
#345 |
Because compromise ®
Drives: Red Herring
Late reply but Nameless developed the headers used by Cosworth.
#346 |
Drives: Corolla GT
Better get some STI or TRD engine mounts ( Same stuff anyway)
Very minimal vibration (from the gearbox mount) which settles after a few thousand kms. I installed the gearbox mount later and had the two front mounts first.
| The Following User Says Thank You to Thefalls For This Useful Post: | Mike_ZN6 (07-12-2021) |
#347 |
Go for the group N STI mounts.
| The Following User Says Thank You to jflogerzi For This Useful Post: | Mike_ZN6 (07-12-2021) |
#348 |
Drives: 2016 Scion FRS
Good luck getting the STi mounts. And if you find 2 sets, let me know!
I haven't noticed the issue with the subframe and I'm on stock mounts launch the car hard for autocross. My concern when I put the header onto the car is that there is only maybe 2 or 3 mm between the tubes and the radiator support. I was worried about melting my fans, but it hasn't proved to be an issue so far. |
| The Following User Says Thank You to steverife For This Useful Post: | Mike_ZN6 (07-12-2021) |
#349 | |
#350 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
WiSh I'd known about this before I ordered a Borla which is enroute now.
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
