Old 07-08-2021, 03:34 AM   #1
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
GR 86 torque curve for Assetto Corsa
I wanted to virtually compare the on-track performance of 2022 against 2017-2020 and 2013-2016.
To achieve that, I've decided to create a virtual '17 and a virtual '22 based on the '13 that comes in the game.
I'm assuming the main differences are just the torque curve and the final drive, and that the final drive of 2022 is the same as 2013-2016.
Here's a screenshot from https://acstuff.ru/u/torque-helper/ vs the torque curve in the in-car display:
Here are the numbers I entered into that tool:
0|125
1000|165
2000|205
2500|227
3000|241
3300|248
3700|250
4000|242
4100|240
4500|240
4800|244
5000|245
5600|241
6000|240
6500|238
6800|236
7000|232
7250|222
7375|215
7500|205
8000|0
Old 07-08-2021, 03:42 AM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Here are the same numbers, subtracting 13% for drivetrain loses (I don't know why the tool doesn't allow that),
which matches what AC did to the 2013 Toyota 86 compared to the spec sheet:
0|108
1000|143
2000|178
2500|197
3000|209
3300|215
3700|217
4000|210
4100|208
4500|208
4800|212
5000|213
5600|209
6000|208
6500|207
6800|205
7000|201
7250|193
7375|187
7500|178
8000|0
These are the values I'd enter into power.lut for this car.
Old 07-08-2021, 04:04 AM   #3
Kronk
Drives: Planning for GR86
Is that torque curve official? There’s a strange drop after 3k rpm
Kronk is offline   Reply With Quote
Old 07-08-2021, 04:07 AM   #4
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
This is the same torque curve that the real car shows in the instrument cluster.
It's been discussed on multiple other threads before.
Good news is that the new torque dip is much smaller than the old one.
The Following User Says Thank You to timurrrr For This Useful Post:
Blighty (07-09-2021)
Old 07-09-2021, 10:41 PM   #5
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Looks really close, wouldn't be more than 1 ot 2 nm off I would guess!
I think potentially there is a slightly sharper curve down after 7k than is what is represented on the image, but I might be imagining it because your running it through to 0 at 8.
Is that forced in AC, ie do you have to run it our to 0 at the top gearing?
Blighty is offline   Reply With Quote
Old 07-09-2021, 11:53 PM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks!
IMO these numbers might be interesting even for folks who only have general interest in the car, but no interest in AC.
... because your running it through to 0 at 8.
Don't know if it's strictly required, but this is how all other configs I looked at have.
Old 07-10-2021, 04:04 AM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I found out that RaceChrono has a mode that allows you to log data from Assetto Corsa
(RaceChrono can't stop amazing me), so I couldn't help but log some data.
I did a few laps at Laguna Seca in the '13-'16 GT86 that comes with in the game.
According to my calculations, the built-in torque curve produced ~167 wheel hp,
which is typical for these cars irl.
Car setup:
  • -1.7º camber all around (tweaked the car config to allow such camber adjustments)
  • 0 toe front, 0.1 toe rear per side
  • Street tires
  • TC off
  • Otherwise default
  • Track conditions: "Ideal"
My opt lap in the GT86 was 1:48.63
Then I also did a few laps in the same car with the same setup, but with
the torque curve from the earlier post (~197 wheel hp, matches what Toyota folks say).
My opt lap in the "GR 86" was 1:46.05
I can certainly polish my laps slightly, but I don't think I can
easily shave off more than a few tenths from these opt laps.
Here's the comparison between speed traces of the best laps in each car:
If you trust such a testing approach, looks like we'll be
seeing 4–5 mph of difference at the end of longer straights,
and ~2.5s of difference per lap at Laguna Seca.
It's important to note that my 1:48.63 lap in the GT86 is over
2 seconds faster than the 86DC Stock class record (1:50.78).
This can be explained by many factors, such as:
  • The virtual model of the track is different (fewer bumps?)
  • The virtual track had "ideal conditions"
  • The virtual Street tires generate more grip than GT Radial SX2
As another data point, I'm seeing corner speeds in the sim 1–2 mph
higher than my car does irl in the 86DC Street class.
(wider tires than 86DC Stock, coilovers)
Having said that, I think the "4–5 mph speed, 2.5s per lap" difference
is the right ballpark.
The Following 5 Users Say Thank You to timurrrr For This Useful Post:
fredzy (02-08-2022), HKz (07-11-2021), jflogerzi (07-11-2021), Ohio Enthusiast (07-11-2021), Sport-Tech (07-10-2021)
Old 07-11-2021, 01:36 AM   #8
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Using your power.lut values, I got a similar differential in times, although my speeds were slower (I used an otherwise-unmodified car, street tires, TC on, `fast` track conditions).
Sport-Tech is offline   Reply With Quote
Old 07-11-2021, 01:58 PM   #9
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I thought assetto corsa used some of the truest representation of many tracks since they used laser scanning, albeit not sure how much for laguna. Maybe better times could also be due to having less fear with higher cornering speeds. I know I push my speeds higher in assetto than I would in rl...of course many runs have resulted in wrecks lol
HKz is offline   Reply With Quote
Old 07-11-2021, 03:12 PM   #10
jflogerzi
jflogerzi's Avatar
Very cool. Thanks for the info!
2013 Series 10 FRS #553
Old 07-11-2021, 03:44 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
There's only so much you can do with laser scanning.
You can't laser scan how grippy the surface is
Also tracks change. Notably, the inside of the first apex, and the right runoff area in the
downhill part of The Corkscrew are now more drivable irl than what it was a few years ago.
The track in AC doesn't have those, so I presume it was laser scanned before those changes.
I've heard CotA is getting bumpier each year, that's another example of the limitation of laser scanning.
Don't know to what degree it applies to Laguna.
I'm trying my best to drive the same way in AC as I would in real life, leaving roughly as much "safety runoff".
Definitely not enough difference to explain multiple seconds of difference.
HKz (07-12-2021)
Xbox one - Forza 6, Assetto Corsa, Project cars - ONLINE play? rice_classic Off-Topic Lounge [WARNING: NO POLITICS] 4 02-06-2017 05:23 PM
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 05:10 PM
Customizing the torque curve using ROM Raider illmatic_frs Software Tuning 8 02-15-2016 02:12 AM
Assetto Corsa - Racing Sim merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 4 01-15-2015 06:07 PM
Ideal street torque curve Bischoff Forced Induction 29 05-03-2014 11:53 AM
