Old 06-23-2021, 02:04 AM   #141
gpvecchi
gpvecchi's Avatar
No, sorry, I casually found it looking into some japanese car enthusiast website...
Old 06-23-2021, 02:21 AM   #142
Compelica
Compelica's Avatar
Drives: 86 GT
No worries. Found this on Minkara talking about it but not much in depth, however I'm certain there's more around.
https://minkara.carview.co.jp/userid...694/parts.aspx
Compelica is offline   Reply With Quote
Old 06-23-2021, 03:04 AM   #143
saltywetman
Drives: 2020 Toyota 86 GT 6M
Interesting, the blogger was saying the 2 rear hangers should be changed but the ones in front of the silencer should be left alone. Has anyone changed just the rear 2 first then compared that to changing all 5? I just changed all 5 at once since i was lazy and didn't want to bother jacking the car back up lol
saltywetman is offline   Reply With Quote
Old 06-23-2021, 03:34 AM   #144
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
From the previous posts, it is said that the other 3 installed resulted in an even quieter in-cabin experience.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
saltywetman (06-23-2021)
Old 06-26-2021, 09:36 AM   #145
BoxerRumble
Drives: 2015 Blue BRZ
Hi, I am wondering if anyone has used these alternate hangers in place of the STI OEM part, and the results? We are probably splitting hairs here, but I thought I'd ask...
GrimmSpeed 12mm Two Position PolyUrethane Exhaust Hanger Set of 4 Universal
Perrin 12MM Red Exhaust Hanger for Subaru Models 2008+ WRX/STI
Cusco Exhaust Hanger 12MM Blue for Subaru WRX / STI
Kartboy 12MM 0.750" Extended Exhaust Hangers 2015+ WRX/STI 2013+ FR-S / BRZ
BoxerRumble is offline   Reply With Quote
Old 06-26-2021, 09:58 AM   #146
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I used the Cusco ones because the Greddy SP likes to slip off the factory ones. They are much stiffer than the factory hangers, so I imagine they increase NVH in theory, but I didn’t notice a difference between Greddy on stock hangers and Greddy on Cusco hangers.
Old 06-26-2021, 11:42 AM   #147
jflogerzi
jflogerzi's Avatar
I have finally had some longer trips with the hangers. They definitely do make a difference. Is it mind blowing no but it's there. For the cost it's a no brainer. Funny is just swapped to OEM header from my 4-2-1 and the in cabin noise between the 2 was not that much different. Kinda supprised me
2013 Series 10 FRS #553
Old 06-27-2021, 12:56 PM   #148
BoxerRumble
Ok sounds good, it looks like I can get the Cusco ones the most readily. Did you replace all 5? And did you have drone that got cured? I have Tomei UEL / Stock OP / Stock FP / Nvidia N1 SS CBE and the drone is killing me.
Old 06-27-2021, 12:57 PM   #149
jflogerzi
jflogerzi's Avatar
This will not sure that level of drone. You need to ditch the N1
The Following User Says Thank You to jflogerzi For This Useful Post:
Yoshoobaroo (06-27-2021)
Old 06-27-2021, 02:29 PM   #150
Yoshoobaroo
TRACKBREAD
I did not have drone with the Greddy. The N1 is the drone source, no amount of bushings can fix that.
Old 06-27-2021, 11:17 PM   #151
saltywetman
The cusco ones will make things worse rather than better because it's stiffer which will increase the amount of resonance transferred into the cabin
Old 06-28-2021, 06:25 PM   #152
BoxerRumble
Shoot, I just placed an order for 5 CUSCO exhaust hangers! I realize the Nvidia N1 itself causes a lot of drone and these hangers may not fix it (or by much). I don't want to get rid of the Nvidia because I just bought this car 15 days ago, and the reason I bought it was for all the mods (headers, OFT, coilovers, exhaust, CAI) at pretty much the same price of a non-modded car. So I don't want to start replacing mods, I'd rather use any money to by other/new mods. Plus, there is one bonus of at least some drone: my 2 teenagers may THINK they are going faster than they are, and not speed.
So to reduce drone, I will be taking a multi-faceted approach and try these hangers first, and if not try to get a J-Pipe custom made, and/or save up and buy a dual resonated FP or FP with Helmholtz - all that is on the table. Even stuffing the trunk by the spare tire with blankets or sound-muffling pads could be an option (as I saw in another post).
However, I have read and re-read this thread many times and I thought that the reason the cabin noise / drone was reduced for the original poster is because the stock FRS/BRZ has too much slop / play / movement in the hangers? The STI part number hangs them more securely (or so I thought), reducing vibration into the chassis? If so, then the CUSCO part which I think is polybronze should hold them even more firmly? I thought the person who posted them above said he had success with the CUSCO's, no ?
Old 06-28-2021, 06:57 PM   #153
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
You can have too much of a good thing. Usually the tradeoff for a stiffer bushing or mount of any kind is more noise and vibration, which matters a lot less in a racecar than in a car you need to commute in or be able to drive comfortably on the street for any length of time. Everyone is different in terms of how they perceive noise and how comfortable they are with things, so you may find your planned change totally livable while someone else couldn't live with it on a daily basis.
You already bought them, so give it a try and see what happens. If it's worse, you can try a different solution.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 06-28-2021, 07:25 PM   #154
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
If you're willing to invest so much time & save up the money to a multifaceted approach, you can probably spend the same amount by simpling selling the N1, and using those funds + saved money to buy a quieter exhaust. I see used N1's for sale all the time, so including your comments, that must be a sign it's not an easy exhaust to live with.
The drone issue doesn't appear to me a play/movement issue with the hangers, but the rubber durometer/ability to absorb and dampen vibrations. The STI/JDM hangers reportedly have more rubber material, which means better absorption and dampening. The CUSCO hangers are polyurethane, which will reduce movement (but that's not really the issue to begin with), but should technically add more vibration due to the nature of the material.
If you re-read what the member posted about the CUSCO hangers, they didn't have an issue with drone with their exhaust to begin with, so that was not the intended purpose. They said they used the CUSCO because their exhaust kept slipping off the stock hangers.
Cliff notes - The Invidia N1 is the root issue, and you may waste of a lot of time/money trying to make it more livable. Much easier and will probably save you lots of time/money/headache in the long run if you sold the N1 and got a different exhaust.
The Following 6 Users Say Thank You to NLSP For This Useful Post:
DocWalt (02-22-2022), Jdmjunkie (06-29-2021), norcalpb (06-28-2021), Overdrive (06-28-2021), saltywetman (06-29-2021), Yoshoobaroo (06-28-2021)
Ecutek discovery solidsnake11 Software Tuning 7 08-25-2020 08:38 AM
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 11:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 04:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 07:58 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 09:22 PM
