#407 | ||
Drives: Q5 + BRZ + M796
I've read that article before, and I read it again. I don't see any point in arguing over a few percentage points. I'll concede a few percentage points. If I were to truly claim 97% then I would need to also claim to be referring to a particular study on a particular point in time, and even then, 97% isn't a hard number. There is a certain amount of implications that when someone is sharing a perecentage, they are sharing a relative number. I could have said most or almost all, but that can have much more interpretation. At the same time, when I say 97%, I assume readers understand that I didn't just read the minds of all climate scientists, and I don't know their swaying consensus at any given moment. I assume a reader will interpret the 97% as relating to something with some sense of accuracy, but that the point is to suggest it is an overwhelming consensus. It is an overwhelming consensus. It doesn't matter if it was off or if the number changes by 3% or 10%. Quote:
Now, depending on how you ask the question, you will get the very, very, very typical responses from scientists, which is to use qualifiers such as, "the evidence suggests, but I don't know." Scientists will rarely ever say with absolute certainty that something is for certain because they want to leave room for options, so the level of certainty expressed by these scientists should be viewed with respect. The point is that the anecdotal conversation from a geologist should not weigh much in the face of the overwhelming consensus from climatologists. It shouldn't even sway anyone's opinions. If the person's arguments were convincing then let's hear their arguments, so we can evaluate and discuss their validity here. Until such time, I'll throw in that my brother's, friend's, former boss once worked for a guy who's uncle said climate change is anthropomorphic, and he has three PHDs--one in Ancient Chinese Art, one in French Literature and one in Biblical Studies. Here is some interesting captures from the study discussed in the Forbes article:
#408 |
These seem to support my position that there is a strong consensus and that scientists don't have an agenda other than to provide the research as it unfolds.
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Capt Spaulding (06-26-2021), Spuds (06-26-2021) |
#409 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
Edit: Irace86 has much quicker fingers than I. Nevertheless, I spent a bit of time on the following and insist that you all read it.
![]() Quote:
He goes to great pains to debunk that number critiquing several (what I would call) meta-analyses of papers produced between 2003 and 2016. And, he does, in fact raise legitimate questions about the 97% estimate. His first bar chart leads him to the statement that "... over half the surveys in the publishing category and all the surveys in the non-publishing category are below 97%." Touche But what does that mean? Of the published surveys, none produces a figure lower than 84% and, tellingly the numbers trend upward until 2008 from which point all indicate census levels in excess of 90 % and four come to the infamous 97% number. On the unpublished side, the level of consensus is lower, peaking at 92% in a 2014 piece. But, of the 9 pieces he cites, only 3 indicate a level less than 80% and all were produced before 2014. As a practical matter does the absolute number really matter? You seem to have spent time in an academic setting and are no doubt familiar with the related concepts of measurement error and false precision. I have no idea what the Ns of the surveys in question were and no way of drawing a confidence interval around their various point estimates. What I can say with certainty is that, unless they surveyed the universe of climate (I presume) scientists, each of the numbers provided is subject to measurement error and therefore, inexact. Does it matter that the 97% number is wrong. If it does, we need accept that all survey derived estimates are wrong. It seems to me that what we can conclude from Ritchie's piece is that, given the fractious nature of most scientific communities, there is pretty overwhelming support for the assertion that climate scientists subscribe to some version of anthropogenic climate change. Must we go beyond that? To do so seems almost cruelly pedantic. The chart from the Bray and von Storch paper seems similarly unhelpful. The item they present represents the results of a Likert item measuring respondents beliefs in the anthropogenic foundations of climate change. First, I think Ritchie misread the text of the item. A seven point Likert scale would start at the low end with "Not at all convinced" not "not convinced" which would be scored as a 2. 4 is the "Not Sure" category and 5, 6, and 7 are various levels of positive conviction. As to interpretation, ignoring the "somewhat convinced" group in category 5, over 69 (let's call it 70) % of the respondents were either "convinced" or "very much convinced" of the efficacy of the anthropogenic nature of climate change. All of which leads me to this question: What is your point? To poke a hole in a number which anyone who has done or paid attention to an opinion survey knows is not true? Of course it's not true. A point estimate is, in the best of circumstances almost certainly not correct. The true value will lie within the confidence interval of the survey. The point estimate simply offers us something to talk about. Now, I have rattled on for quite some time, but again, what is your point?
Slow is smooth, and smooth is fast
| The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post: | Irace86.2.0 (06-26-2021), Spuds (06-27-2021) |
#410 | |
![]() ![]() When you say we are doing more to turn that around than any other country, do you have a link for that statement? Is this in total volume or per capita? We have the most improvement to make from a volume and capita perspective, but we aren't leading in renewables in absolute terms or as a percentage of our total production of energy or in EV production or in many metrics, so I am wondering what makes you say that. From these, it looks like China has more green production, Brazil and Canada have the highest percentage of production from renewables, the US is low on EV adoption as a percentage and behind China in total EV sales. What are you finding? ![]() ![]()
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Spuds (06-27-2021) |
#411 |
Per capita seems like a poor measurement in a country like China where only about 60% of it's massive population lives in an Urban area, most associated with carbon emissions. The US is considered over 80% "urbanized" in contrast, but the difference is even greater when you consider the population differences between the two countries.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Spuds (06-27-2021) |
#412 | |
ProCrastinationConsultant
because that reads like an OSHA test. "when are you supposed to stand on top of a ladder?" 1always........10never 97% picked never! we're all safe! [in the background, just-finished-the-test timmy crashes to the floor off a 10' ladder because he was standing on the top to do one last thing]
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (06-27-2021) |
#413 | |||
Also, if you are going to compare differences then you should compare all the differences and not just living location. I believe the per capita values include all emissions from individuals and from industries, and from what I understand, China leads the world in manufacturing, and they are higher per capita than the US. Manufacturing tends to have a larger carbon footprint than other industries. Even without that, the 20% difference can’t account for a greater than doubling per capita that the US has over China. Individually, we are high consumers with poor recycling. Quote:
#414 | |
Dismember
Drives: 2013 Red Scion FR-S
In the countryside, you heat and cool a much larger space, without the benefit of other units insulating your home. You drive to get anywhere, and all deliveries are inefficient. The carbon footprint is dramatically higher. Hence, arcologies are likely the future of much of the human race if we keep growing. The planet can sustain far more people in arcology lifestyles than it can in single family homes. That said, the falling birthrate in industrialized nations suggests that maybe the future will not be so dense. We may see a future where single child families are the norm, and the world population eventually drops or at least flattens out. As for global climate change, (not at Dadhawk) it is abundantly clear that the planet is warming and warming quickly. The evidence is large and keeps piling up. Sure, there are holes in the evidence, but they're insignificant and require a lot of contorting to get through. Mostly they're just illogical. There's also about the same amount of evidence that humans are responsible for the heating. It's not just carbon. It's methane and natural gas and a many other activities we do. We are a polluting our environment, and we're seeing the consequences. Anti-science thinking pollutes minds and gets people killed. I can have my own beliefs, and I can have my own actions, but I can't have my own facts.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Irace86.2.0 (06-27-2021) |
#415 |
I think Dadhawk was thinking that China might not just have urban, suburban and rural lifestyles, but that there was dual standard of livings there, where there are many people living in rural areas at lower standards, which could have less carbon footprint. Unlike people living in rural areas in the US, in China they probably don’t receive packages, have a car, have electricity, etc. I believe this is true of many countries like India too, but it might be even more polar for China. I don’t know. It is probably what Dadhawk was thinking. Outside of some inefficiencies and use of wood for cooking and heating, I tend to think an agrarian lifestyle would have a much smaller carbon footprint.
In general, I agree with all your points.
#416 | |
I'm not arguing the Earth is warming, the data seems to say it is, just as it has done in the past as part of the Earth's cycle. And yes, we Humans are likely contributing to it to one degree or the other.
#417 | |
Dismember
I tried to separate the latter half of what I wrote. , I didn't think it applied to you.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Dadhawk (06-28-2021) |
#418 | |
The Dictater
Drives: '13 Red Scion FRS
Also, the "net emissions" would have to account for how the country may reduce it's emissions, through undeveloped land area for example. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Dadhawk (06-28-2021), Irace86.2.0 (06-27-2021) |
#419 | |
Ultimately, it is emissions that we want to reduce, so total emissions matter, but it is possible that a country could meet a global standard per capita and still produce far more emissions than any other country because of shear numbers. This partially describes China. We need China to improve, but too often people in the US point to China when they should be pointing into a mirror.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (06-28-2021) |
#420 | |
The Dictater
Basically, the target per capita emissions should be subservient to the optimization of a country's strategy to meet an emissions target determined by the amount of Earth it is responsible for. In that way, you replace a variable national target with a generally fixed national target, allowing better planning and execution of the optimized strategy. This also allows greater freedom in devising said strategy. In layman's terms, if you keep moving the goalposts every time somebody kicks the ball, everyone who took the time to aim carefully is going to miss. |
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
| Tags |
| youguysneedlives |
| Planet Earth: The Car Enthusiast | sniffpetrol | Other Vehicles & General Automotive Discussions | 1 | 02-03-2018 11:54 PM |
| Planet Eclipse Geo2 | Gt86_nick | Miscellaneous | 0 | 11-01-2014 11:53 PM |
| Planet Audio 2250D amplifier | Noob4Life | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-16-2013 08:33 AM |
| Like saving the planet? read this | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 02-14-2013 07:09 PM |
