Old 06-23-2021, 10:34 AM   #1
letmethefuqin
Drives: 86
Very sloppy / limp gear stick
Replaced my gearbox today
New forged fork
New throw out
Clutch
Motul g300 oil
Mtec shifter springs
Popped it all in, jumped in the car and Instantly noticed the lack for force back
I basically have to guide it into every gear
Any idea what’s causing this ?
letmethefuqin is offline   Reply With Quote
Old 06-23-2021, 10:41 AM   #2
Ashikabi
Ashikabi's Avatar
Shifter bushing installed correctly? You sure springs were installed correctly?
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (06-23-2021)
Old 06-23-2021, 10:44 AM   #3
Did you get into a Honda by accident?
As Ash said check all your springs, and bushings.
Here are the manuals
https://gt86stuff.onrender.com/t3Portal/
Borden (06-28-2021), jcw99 (09-10-2021), JD001 (06-23-2021)
Old 06-23-2021, 11:29 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
There are two centering springs from sides of gearbox case. Check vids on replacing to a bit stiffer ones by Mtec. As what they do is increasing centering force for lever, i strongly suspect something wrong with those. Maybe stock ones forgot to be put back after whatever maintenance work performed?
Old 06-23-2021, 11:31 AM   #5
Ashikabi
Ashikabi's Avatar
He already mentioned installing Mtecs.
Old 06-23-2021, 12:57 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am going to guess rear shifter bushing not attached or missing.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
jcw99 (09-10-2021), Ultramaroon (06-24-2021)
Old 06-23-2021, 12:59 PM   #7
Ashikabi
Ashikabi's Avatar
That was honestly my first thought
Old 06-23-2021, 03:42 PM   #8
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I don't see what the big deal is here. My old lady has been accusing me of this for years.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 06-23-2021, 03:45 PM   #9
AJ32162
Drives: 2019 BRZ with Performance Package
I also have a limp stick, but I'm 67 years old so I just assumed it's normal.
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
JD001 (06-23-2021)
Old 06-23-2021, 03:48 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
Here's brand placement for you. I'd love to be the sales rep pitching Pfizer to order these. This was actually a giveaway in 2007 in Kuwait.
It's ironic since Viagra will prevent you from needing to put on the brakes. lol
The Following User Says Thank You to wbradley For This Useful Post:
soundman98 (06-24-2021)
Old 06-23-2021, 08:43 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
LOL, mostly looked vid, missed their mention after it
Still, "installed" seems rather "misinstalled". Something obvious/simple .. as they are of different length, maybe used wrong one at wrong side?
Old 06-23-2021, 09:23 PM   #12
Ashikabi
Ashikabi's Avatar
Perhaps
Old 06-24-2021, 12:19 PM   #13
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I've had left-right centering issues with my shifter although my problem was that the shifter was sticking as it came into center, so I'd keep missing gear shifts. I've tried everything people mentioned here including a new rear bushing and the mtec springs, so I know the effects of these things.
For clarity, the mtec springs are only up/down (fore/aft) centering, and make for a more positive shift feeling as you are going in and out of gear. This is clearly not your problem as you are having left/right sloppiness.
Some people have mentioned the rear shift bushing and if it's missing, it can cause a sloppy feeling so check for that, but seeing your video, and knowing how my shifter felt without it, I not sure that is your culprit. Still, it's easy enough to check because it's visible from under the car or by removing the shift boot from inside the car and looking towards the back, so make sure it's there. If it's not, put it in and see what happens.
If that's not the issue then most likely there is something missing or wrong in the assembly in the transmission. Left/right centering is handled by bushings and detents in the transmission. I personally reached this point with my transmission and took it to a local transmission shop and $450 later, my problem was solved. YMMV.
Lynxis is offline   Reply With Quote
Old 06-24-2021, 12:51 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
"For clarity, the mtec springs are only up/down (fore/aft) centering", hmm, are you so sure on that?
They certainly changed centering force for me from sides, from 1-2 & 5-6 to 3-4. And given that they are bolted in from sides from gearbox, that's what they should. I'm suspecting, that some other mod you done at same time made impression that they do other thing then what they were designed for. What affected ease of getting into gears, mentioned up-down, was oil and transmission mount & gearbox bushing. Nothing in relation "centering" right-left, which mtec's did. Even ftspeed's video at mtec spring product page tells that it's about centering right-left.
My 'Sloppy Stage 2' 4.8 swap FRS Chickeneatman Engine Swaps 3 08-17-2020 10:36 AM
KW coilover boxing sloppy? Ranran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 02-17-2020 10:34 AM
Buzzing/vibrating gear stick paulca Issues | Warranty | Recalls / TSB 49 10-12-2017 12:47 PM
Shifter is obnoxiously sloppy Takumidesh Engine, Exhaust, Transmission 14 04-25-2017 03:58 PM
Gear Stick HELP FaNtaSy Engine, Exhaust, Transmission 12 03-18-2013 12:03 AM
