Old 06-12-2021, 03:56 PM   #1
ft86tr
Drives: Zenki WRB BRZ
Advance Multiplier always 1 with 95 RON (OTS STAGE 1)
Hello everyone!
I have just bought my OFT. With the stock tune, IAM was showing always 0. Then I flashed OTS Stage 1 ZA1JF10I (MY2016 EU 6AT) v4.03. Then IAM became 1 and I see almost no knock correction with 95 RON. The IAM never dropped. Is there a problem with OFT or my Car since fuel quality is low in my country. Thank you for your help.
Edit: There is nothing happening with FLKC
ft86tr is offline   Reply With Quote
Old 06-12-2021, 07:51 PM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Do a log of some very spirited driving to be sure it`s not bad in any way. 1 is perfect for the multiplier eg. 1IAM x 25deg ignition advance is 25deg advance 0.9IAM x 25deg is 22.5deg ign advance. This would mean a timing reduction from knock and a data log would tell.
Old 06-13-2021, 08:19 AM   #3
ft86tr
Thank you . And as far as i know, v4 tunes has initial IAM 0.7 . However, my IAM is always 1 even on start. I am worried about false reading.
Old 06-16-2021, 07:02 PM   #4
steve99
Drives: FT86
update oft via open flash manager and also update the Templare file manually its separate process both can effect oft logging. OFT wont log a lot of stock tunes correctly you need to be runnog an oft tune for logging to work correctly
Old 06-20-2021, 05:06 PM   #5
ft86tr
I have just updated of manager and my template manually. In stage 1 tune my IAM always stuck at 1 (even on starts). Doesnt v4 tunes IAM start with 0.7?
Old 06-20-2021, 06:45 PM   #6
steve99
Drives: FT86
yes all oft v4 petrol tunes iam initial 0.7 on E85 tunes its 1
Old 06-21-2021, 07:03 AM   #7
ft86tr
Yes but mine starts with 1 with v4 petrol tune?
Old 06-21-2021, 09:37 PM   #8
steve99
Drives: FT86
open tune in romraider and check but id say its logging issue with oft
Old 05-16-2025, 08:06 PM   #9
ft86tr
Switched to wayneroms and now it works. Does anyone know how to fix logging issue with OTS maps?
What does it mean when advance multiplier increases? RedPandas Software Tuning 7 06-17-2019 09:29 PM
How to set Advance Multiplier...when you first start your car? chazmuska Software Tuning 6 07-25-2018 08:30 AM
Question about Advance Multiplier Jasonb Software Tuning 20 03-06-2018 07:37 PM
Advance Multiplier at 1 in log? orangespark Software Tuning 5 10-21-2015 04:32 AM
advance multiplier = 0 why???? agent47 Software Tuning 11 01-29-2015 12:11 AM
